Drywalling cost?
Old Mar 9, 2013 | 04:54 PM
LMS Residential's Avatar
LMS Residential
Originally Posted by 85e150six4mtod
Thanks for the tip. I am thinking the premixed crap in the box. I used some of that before with "acceptable" results in the garage portion. Paper tape--the stick-on mesh stuff looks so easy.....
I will need some corner beads. I saw paper/metal jobs that look like a better fit for what I'm doing. I heard plastics referred to as junk. Any thoughts on premix and plastic corner beads?
Properly applied (3M cornerbead adhesive plus staples) plastic corner bead is FAR superior to metal.
On edit, be sure to coat both the cornerbead and drywall surfaces, its a contact cement.
Old Mar 9, 2013 | 04:56 PM
LMS Residential
Plus3 is a particularly decent premix...good for bedding and finishing. Slow dry, fairly easy to sand.
Old Mar 9, 2013 | 05:00 PM
LMS Residential
I've yet to see (in 35 years of building) mesh tape that doesn't eventually crack open from subtle movement and seasonal expansion/contraction. It is an inferior product. Paper tape tends to move a bit with the substrate.
Old Mar 9, 2013 | 05:07 PM
dustybumpers's Avatar
dustybumpers
I like the lightweight mix for new users.
Put down a mud bed, set your pre- torn to lengths tape down. Hold the tape with a 4" knife, use a 6" knife to drag it flat.
Cover with a thin coat of mud with the 6" knife. Make sure to get it fairly smooth. Corners have to be folded, then put in the same way, one side at a time.
2nd day, use an 8" knife to "block" keep it smooth. Do corners one side at a time. You have plenty of time, stretch it out, and make sure the mud is dry before you put the next coat on.
they make a sander that hooks to a shop vac. it uses the wire screen sanding paper. Well worth it for a small job, it keeps the mess down.
After you sand put a coat of primer on, let it dry, then go back with the 6" knife, and patch any blemishes, those you can sand with a damp sponge. Once your satisfied, go ahead and paint
Old Mar 9, 2013 | 05:08 PM
dustybumpers
I agree on the mesh tape. Only thing that is good for, is setting your coffee cup in to keep it from spilling over
Old Mar 10, 2013 | 08:17 AM
gnwalker's Avatar
gnwalker
Find the source of the moisture that caused the mold and fix it. Otherwise it will be back and mold will grow on paint and primer
Old Mar 10, 2013 | 02:57 PM
85e150's Avatar
85e150
Condensation on the ceiling due to high humidity, higher humidity from the bathroom shower, high temps and a closed up room. It got into the ceiling fan box and went from there. I should have torn the whole thing out right then and there.
I did a little searching and other research and found this is not unheard of with cathedral ceilings. Our neighbor had the problem in an upstairs bedroom and ended up having to replace rafters and roof sheathing. It's real trouble in Florida and other high humidity areas.
Cathedral Ceilings – Mold and Moisture – Problems and Solutions | Ted's Energy Tips
You can find all kinds of hits with a "cathedral ceiling mold" search.
Mine was built to be the sealed up type. Even if it had been built with eave vents, insulation baffles and a ridge vent, the humidity would have still condensed on the ceiling.
So, I now have a roof vent. I did not want to tear out the whole ceiling and put in eave vents. So, I will have the original insulated sloped ceiling, and the new flat section will have insulation on top of the drywall, with a mini attic above it, open via the dormer vent. In addition, I am putting a ventilation fan on a timer in the flat ceiling, along with a couple of passive vents, all ducted to that dormer vent.
It's probably not the best solution, but I have not seen anything better that does not involve more demo and cost.
85e150's Avatar
85e150
duplicate post
Old Mar 10, 2013 | 03:41 PM
dustybumpers
Use green board when you put it back together, that will help some. It's not waterproof, but is more resistant than regular gypsum board.
They make a purple board now, I see them using it outside here, but I'm not familiar enough with it to comment on it, so if anyone here knows anything, let us know.
I would also insulate with foam sheets and use metal tape to seal all the cuts and edges. Keep the foam about 1" below the roof surface, so there is an air pocket there, likewise, try to keep a 1" pocket of air on top of the drywall board.
I have cathedral ceilings in this house too. I ended up having to cut vents into the roof every 10', Halfway down the roof line
Old Mar 10, 2013 | 05:08 PM
LMS Residential
Regular greenboard should not be used on ceilings unless the ceiling is framed @ 12" oc (USG spec). Even then greenboard on ceilings is not IBC or UBC compliant. Catastrophic failures (full ceiling collapse) have occured. The panels do not derive any strength along the axis as conventional drywall does.
The purple panels are manufacturer spec'd for ceilings but many building codes still do not approve that use.
National Gypsum Company
ford2go
Dec 8, 2013 08:32 PM
stu37d
24
Nov 7, 2008 10:01 AM
BuiltToughF250
21
Apr 13, 2006 10:16 PM
FLgargoyle
Jan 9, 2005 10:02 AM
