Lost vacuum
Old Mar 8, 2013 | 09:46 AM
bashby's Avatar
bashby
Originally Posted by tjc transport
or you could go with this one for 1/6 the price.
Ford Diesel HVAC 4WD Electric Vacuum Pump New | eBay
I don't think that one will run a brake booster, its just for the hvac controls.
Old Mar 8, 2013 | 09:49 AM
RIKIL's Avatar
RIKIL
Originally Posted by blkF250HD
If anything, having no vacuum to the FPR will cause a rich condition at idle or low throttle, but it won't be the end of the world. Do you have AFPR installed and set to what works best for your tune and injectors? Pulse width is the main controlling factor in how much fuel gets into the engine anyways.
I forgot to mention with the 255 lph fuel pump, I am using Siemens DEKA 60# injectors, so there is a very short pulse width with these. With the combination of these factors, could that be what is causing my pressure to drop? If I have sufficient volume as rla2005 said.
Old Mar 8, 2013 | 09:50 AM
tjc transport's Avatar
tjc transport
i ain't rite
DOH!!!
missed that part!
Old Mar 8, 2013 | 09:53 AM
RIKIL's Avatar
RIKIL
DOH!!!
missed that part!
Couldn't I just buy 16 of them and chain them together???
Old Mar 8, 2013 | 03:18 PM
tjc transport
i ain't rite
there ya go!!!
ricer math!!
Old Mar 11, 2013 | 07:49 PM
RIKIL's Avatar
RIKIL
I am not sure what is up with the FPR yet, I think my gauge might be bad.
But as for the loss of vacuum...I was wrong. My brake booster was bad but I thought it wasn't working right due to lack of vacuum.
I also was able to verify another vacuum is present in a blown motor, I connected a PCV to my intake and I can feel and see (if I use a match) flow going in the valve cover on the other side. I've seen a few posts around and had questions myself how useful this will be if I have the blower. For whatever range it works in, it might help a little.
nddragon01
2004 - 2008 F150
Oct 4, 2017 06:36 PM
monte97z
Apr 15, 2017 10:13 PM
Bikedude987
May 24, 2012 03:25 PM
jemini
May 2, 2008 07:54 AM
hotbbb
Feb 2, 2004 02:37 PM
