Question for the inline 6 experts
Old Mar 6, 2013 | 08:02 PM
1918ALF's Avatar
1918ALF
Hello all, I have the timing cover off my 4.9 300 6 (1988 F150). The engine has about 350,000 on it... I have the timing cover off so I can replace the crankshaft seal and put one of those sleeves on the balancer and replace the seal. It started slinging oil out recently. My question is... should I replace the timing gears? Both are in excellent condition (it appears). Stuff these days is made so cheap I don't know if I would really accomplish anything replacing the good ol American gears (even with the mileage) with a chinese set from Auto Zone or O'Reilly's.
Old Mar 6, 2013 | 09:48 PM
ctubutis's Avatar
ctubutis
If it ain't broke, don't fix it.
Old Mar 6, 2013 | 11:34 PM
6978sghfbjklgdfsjhkl's Avatar
Interesting project you've got going there. With that many miles on this engine, makes you wonder just how much of a can worms you may not want to begin opening up.
Hopefully you won't regret not replacing your front main bearing..(and of course once the pan is off, you my as well replace ALL bearings, and depending on the year, the rear main seal)
Hopefully you can keep most of the old gasket material from dropping into the oil pan (may I suggest a shop vac to help while scraping)..
like he said.."if it ain't broke"...
Old Mar 7, 2013 | 07:58 AM
ctubutis's Avatar
ctubutis
81-F-150-Explorer in 80-86 has a 300 I-6 with over half a million miles on it and I don't think he's ever replaced his timing gears.
I've read the tales of others here who have gone to replace those things, getting the gears off "the right way" requires special pullers that nobody can find or afford, which leads to all sorts of drama as people destroy things while removing them using other methods.
Talk about a can of worms.....
Old Mar 7, 2013 | 09:58 AM
Yaga1973's Avatar
Yaga1973
Elder User - What???
If your gears are in good shape, not cracked or super sharp from wear, then I would leave them alone. Just replace your seal and call it good.
burnthelight88
Dec 8, 2016 08:32 PM
bigb609
Nov 21, 2011 05:35 AM
timbersteel
17
Nov 14, 2010 11:00 PM
Hometown Pride
16
May 21, 2007 08:02 AM
CC
Feb 11, 2000 10:14 PM
