Sponsored by: Real Truck
Electrical issue
Old Mar 6, 2013 | 03:31 PM
Markmonteverde's Avatar
Markmonteverde
Electrical issue
I have a 2008 F-250 diesel, the radio preset stations buttons won't light up, line in and radio control buttons on steering wheel does not work, check all fuses and cant find anything wrong with it, can someone out there help me with an advice.
Old Mar 6, 2013 | 04:39 PM
Yahiko's Avatar
Yahiko
On the head unit is that the preset you talking about or the wheel?
Does the other wheel buttons work? If not I would be thinking clock spring
may be bad. If the preset lights are the ones in the head unit it may be as simple
as a failed LED/lamp in the unit it's self.
I don't happen to have the wiring diagram for you year. You may want to check and see
if the head unit is getting power from the illumination circuit. To do that your going to
have to pull the unit out some to get at the wires and check the voltage at the plug
when you turn the dash illumination on and off.
Sean
Old Mar 11, 2013 | 12:03 PM
Markmonteverde
Thanks Sean, I will try your advice.
rowekmr
Apr 6, 2019 06:00 PM
SUPERDUTY_08
Feb 13, 2012 08:50 AM
Country Traveler
Feb 11, 2011 09:24 AM
kaerch
2004 - 2008 F150
Dec 24, 2007 08:17 PM
S4patrick
Feb 6, 2006 01:13 PM
