Old Jun 5, 2003 | 04:35 AM
baddad457's Avatar
baddad457
360/390
C8AE-H's came on std 428's ( non- CJ/SCJ motors) I hope they've been running it with lead substitute otherwise the valves have probably been hammered into the heads. The 390 in my 68 Monterey has multiple belt pulleys ( 3 I think)
Old Jun 6, 2003 | 06:55 PM
ford_nut's Avatar
ford_nut
guys
managed to pull some #s of the intake today. ill have a stroke measurement within a few days. Here are the #s on the MANIFOLD:
C7TE 9425F (i know this is a 67 something?)
also
a large "T" then the #s 7H21
any more ideas??
one other thing, this engine has a strange 2bbl carb....it looks antique! LOL the best way I can describe it is.....tall....and yes, i looked for #s or a tag and there are none!
Thanks
Ben
Old Jun 6, 2003 | 07:10 PM
baddad457's Avatar
baddad457
360/390
The intake casting #'s don't mean squat . The block casting #'s are all that matter. The carb may be a Propane unit?
Old Jun 6, 2003 | 07:15 PM
BB's Avatar
BB
360/390
Ben, that’s a 2V pickup intake, date coded Aug. 21, 1967.
The funny-looking carb. could have a governor on it.
It will be interesting to find out the stroke.
Barry
Old Jun 6, 2003 | 08:59 PM
ford_nut's Avatar
ford_nut
Barry
no it doesnt have a governor. Matter of fact, the governor is run seperately via a fan belt. its funny bec the alternator is a 3 pulley setup. I should take pics of this thing but i dont have a digitial camera.
Moreover, the carb is NOT set up for propane; it is a 2V gas unit all the way.....
regards
Ben
Old Jun 6, 2003 | 10:10 PM
baddad457's Avatar
baddad457
360/390
Sounds like someone swapped out the original HD ( FT) truck motor the chipper had and replaced it with a std FE from a car and dressed it in the truck accessories.
Old Jun 17, 2003 | 11:58 AM
ford_nut's Avatar
ford_nut
OK
took me a while to do it, but i did the good ole dowel check to verify stroke. I measured a rough 3.25 inches between TDC and the bottom of the stroke. does this help??
thanks
Ben
Old Jun 17, 2003 | 02:55 PM
gtex's Avatar
gtex
360/390
I'd have to say it still has a 330HD motor block at least. If the stroke is indeed only 3.25".
The FEs 360-428 are usually , 3.5" , 3.78" or 3.98" as far as I know.
Hopefully the gurus will clarify here shortly.
Old Jun 17, 2003 | 05:54 PM
BB's Avatar
BB
360/390
Ben, did you check the stroke via the #1, #4 route or did you rotate the crank to try and find BDC?
Barry
Old Jun 17, 2003 | 07:27 PM
ford_nut's Avatar
ford_nut
Barry
I put 12'' piece of dowel in the #1 cyl and i rotated the crank until the piece of dowel didnt move upward anymore. I then Scribed a line on the piece of dowel. Then I carefully turned the crank with a socket until the dowel went all the way into the cylinder. I watched until it wouldnt fall anymore. At that point, I scribed another line. Then I Took my trusty tape measure and measured the distance, I did it twice and i came up with roughly 3.25 inches. Maybe I did it wrong but thats how i thought you had to do it. If it IS a 330 block as Gtex said, is that a junk block?? What yrs were they made and what applications were they in??
Thanks guys for all the help!
regards
Ben
Old Jun 17, 2003 | 07:47 PM
gtex's Avatar
gtex
360/390
I'm not even sure that a 330 has a 3.25" stroke. I just know that the 352 and up have a longer stroke.
But the 352 bore of 4" with a 3.25" stroke is 327 CI, so it's certainly a possiblilty.
cool, maybe you have a Ford 327 :-) I always thought was a cool displacement number.
I'm sure that somebody who knows these HD blocks better than me will clear this up soon.
Can you get a good measurement on the bore?
Old Jun 17, 2003 | 10:25 PM
BB's Avatar
BB
360/390
I'd try that stroke test again. Rotate the damper to TDC on the pointer, shove the stick down #1 making sure it's parallel with the bore, mark the stick with reference to the top of the spark plug hole. Now take the stick and shove it down #4 and make another mark. Measure the distance between the two marks, this should get you close.
A 330 has the same stroke as a 352 but with a tiny bore of 3.87".
Barry
Old Jun 17, 2003 | 10:48 PM
  #28
gtex's Avatar
gtex
360/390
So 3.5" is the shortest stroke in an FE or FT engine?
Old Jun 18, 2003 | 12:12 AM
  #29
BB's Avatar
BB
360/390
The shortest stroke crank is out of a 332, 3.30 stroke x 4.00 bore.
Hey, I checked out another reference and got another digit out of the 330 bore, it's 3.875"
Old Jun 18, 2003 | 07:15 PM
  #30
ford_nut's Avatar
ford_nut
Barry they are callin for serious rain here so the soonest i can do the stroke test is early next week. Ill post back with what i find! Thanks again for all the help and advice!
regards
Ben
chipper29
Mar 12, 2025 07:57 AM
dirty dirt
Jan 15, 2014 04:32 PM
z scpaes
Mar 10, 2010 11:29 AM
FordF350Baby
Sep 20, 2009 12:48 AM
