Old Jun 1, 2003 | 07:31 PM
ford_nut's Avatar
ford_nut
Guys
today I picked up a well-used chipmore wood chipper. I always thought that these things came with the good ole ford straight sixes. The owner told me that it came originally with a Ford 390 but he since then replaced it with a 360? I dont know. It seems kinda strange that I have a 360 or 390 V8 in a wood chipper. Does anyone have any ideas here? THe chipper has 16'' blades and on the title it is a 78. I think i saw on the block somewhere a C7ME casting #. The exhaust manifolds are NOT the log type. Instead, they come down like the old ram horn manifolds. I didnt get a chance to look at the manifold in gr8 detail yet. Any ideas??
regards
Ben
Old Jun 1, 2003 | 08:03 PM
Chas1234's Avatar
Chas1234
360/390
sounds very interesting - the only chipper I have used had a 300 I6 on it .
posting the casting numbers would be helpfull but also verify the stroke to see if it is a 360 or a 390.
Neat machine
Old Jun 2, 2003 | 10:22 AM
Mike G's Avatar
Mike G
360/390
I believe the "ram" style manifolds came on the FT version, or the "big truck" equivelent of the FE. These are are the 361 or 391 cid's. Have you detrmined it is a V8, sounds like you still are questioning that... Check the different posts, there is plenty of info on checking the actual stroke.
Keep us updated.--Mike
Old Jun 2, 2003 | 10:33 AM
Rat wagon's Avatar
Rat wagon
360/390
the ram exh. manifold came on certain 72-76 trucks w/ fe's also.
Old Jun 2, 2003 | 07:44 PM
ford_nut's Avatar
ford_nut
Mike
heck no! its a V* alright. I have several of the same engines in my trucks--but in a Wood chipper? isnt that too much power?? thats what im questioning!!
Old Jun 3, 2003 | 01:03 AM
baddad457's Avatar
baddad457
360/390
According to the Ford High Performance Engine parts interchange a C7ME block isn't a 360 or a 390, you got yourself a 428!
Old Jun 3, 2003 | 10:28 AM
Mike G's Avatar
Mike G
360/390
Too much power??????
A question I thought would never be muttered....
Old Jun 3, 2003 | 06:02 PM
ford_nut's Avatar
ford_nut
nah i doubt it is a 428!
i couldnt be so damn lucky
but poking around some, i saw what looks like a stamping # on the part of the block above the oil filter assembly
i think it says H22D or A22D if this # doesnt help any , where should i look? Thanks!
Ben
Old Jun 4, 2003 | 10:08 AM
Mike G's Avatar
Mike G
360/390
Check the stroke, that should get you close. There is always the hopes of an A or a C cast into the back of the block behind the flywheel....
Old Jun 4, 2003 | 11:24 AM
chissler's Avatar
chissler
360/390
Sounds like you could chip more than just wood!
Old Jun 4, 2003 | 04:12 PM
Mike G's Avatar
Mike G
360/390
Hehehe
Monster garage that thing and see what it will do to a small import....
Old Jun 4, 2003 | 04:36 PM
chissler's Avatar
chissler
360/390
I'm thinkin' we should take it over to Iraq
Talk about a weapon of mass destruction.
Old Jun 4, 2003 | 06:13 PM
gtex's Avatar
gtex
360/390
I think 427 and 428 blocks were common in industrial applications. Put a ruler to that stroke and bore.
that's my dream, to run across a 427 in some rarely used industrial machine :-) I understand the block is about the only part worth anything. The rest of it is low compression durability parts.
Old Jun 4, 2003 | 07:59 PM
baddad457's Avatar
baddad457
360/390
If it's a 428 then it will have a cast-in counterweight on the flywheel or a welded-on one on the flexplate. 428's also have "428" cast into the cylinder sleeve just inside the middle freeze plug hole in the side of the block.
Old Jun 4, 2003 | 09:49 PM
ford_nut's Avatar
ford_nut
Tomorrow I will get some more #'s off the block. I can tell you that it has the double fan belt setup. I read somewhere that the double fan belt setup indicated an early 60's engine? I just remembered that the guy I bought it off of said that this engine came out of a wrecked 60's car to replace the blown 390 that was originally in it. Ill check the stroke with a wooden dowl sometime this weekend when I can tear into it some more. The heads though, are regular C8AE-H jobs. I doubt these heads came on 428s or 427s??
regards
Ben
