Later model gas tank in 78, 79 bronco
I'm looking at doing a fuel injection swap into my 78 bronco and was wondering if anyone knew if a tank from a late 80's bronco would fit in the stock location. My local scrapyard has a later fuel injected bronco with the in-tank pump and everything that I can get, but its sitting in a big mud hole that makes getting measurements difficult. Anyone ever done this?
Hello, I am doing this same swap presently. What did you come up with back then? I haven't had an opportunity to compare early in tank fuel pumps to the 78 Bronco tank hole. But I'm thinking I may be able to swap one in.? It seems as tho the 25 gal tank in a 78 was much the same as one in 87???
I looked at some information recently based on another thread about 33-gallon tanks. Based on pics, it appears to me that a 79 and 96 tank are identical other than the 96 has a larger hole for the pump assembly. But doing an actual comparison side by side would be best to verify.
78BamBam
13
07-10-2018 07:02 PM
oldhalftons
04-12-2005 10:33 PM
Ben_2
09-15-1999 02:12 AM
