tranny-fluid change
transmission fluid and change the filter on an automatic transmission? I
think this is going to be the next attempt to solve the cooling problem I
have been having on my 95 Ranger 3.0, before I do this I am gonna install a
new radiator(old one has a leak now) and install a new fan clutch and belt..
thanx again all you folks for you kind words and suggestions,
faithfully a fordman..............for now.lol :-)
I have the 5R55E auto tranny in my '98 Ranger and I think you have something very similar in yours. Here is a link to a PDF file I put together on how to drop the pan and change the filter. It has diagrams and torque settings, etc. and I even attached the Ford TSB with the Recommended Tranny Fluid Chart. It should help you out: Ranger Tranny Fluid & Filter Change
If you want to do a full flush then you should read through Mark Kovalsky's FTE Tech Article "Changing ATF Fluid in a E4OD and 4R100 Transmission". Mark's article deals with different model tranny than yours and mine, but the flushing technique can probably be utilized and adapted to what we have.
Hope this helps. Good luck!
