Brake drum stuck
Old Aug 8, 2002 | 01:20 PM
stryder's Avatar
stryder
Brake drum stuck
The rear drum on my '90 LD F250 4x4 will not come off. I've completely loosed the adjuster and it still wont budge. I've soaked it for a day with penetrating oil, I've pryed, beat with a deadblow and almost about to use the old theory of if it wont come loose...get a VBFH! Any thoughts? Thanks
Stryder
:-X11
Old Aug 8, 2002 | 01:56 PM
honney's Avatar
honney
Brake drum stuck
You say LD, so is this a SF rear?
Old Aug 8, 2002 | 01:59 PM
SPROCKET's Avatar
SPROCKET
Brake drum stuck
not trying to make you sounds stupid...because I've done this...but your Parking brake is off right? I usualy have to get a rubber mallet and beat the cra*p out of it...sometimes a few taps of a hammer helps.
Old Aug 8, 2002 | 03:50 PM
stryder's Avatar
stryder
Brake drum stuck
Yep, its a Sterling semi-float. The parking brake no longer functions and I've had no problems driving, so Im almost positive its not the park brake. I've tried beating the crap out of it. that's why Im hoping someone else has had this problem.
Stryder
:-X11
Old Aug 8, 2002 | 09:02 PM
92lightning's Avatar
92lightning
Brake drum stuck
Try heating the drum at the axle.
Old Aug 8, 2002 | 09:41 PM
craterjoe's Avatar
craterjoe
Brake drum stuck
there are few problems in the universe that cannot be solved by a suitable application of concentrated phaser fire. but where to find a phaser......
seriously, I have found that using a 16# sledge with caution around the axle shaft has helped me in the past but hit the drum not the axle as if you do the impact will be transferred into the diff and that may open up a whole new set of problems for you.
aside from that if you have poor aim you may be replacing a lug stud or two and try to work in a circular pattern.
CJ
1990 F-250 7.3Ldiesel sc lb
Old Aug 8, 2002 | 09:43 PM
oldblue18's Avatar
oldblue18
Brake drum stuck
Most of the time I beat the drum with a large hammer untill it falls off in pieces. My neighbors really like when I use this method about 2am.
Try it..it really works
Jon
1989 F-150 XL- 4x4, 302, M50D
1995 Bronco Eddie Bauer- 351W, E40D
Old Aug 9, 2002 | 07:20 AM
gwuister's Avatar
gwuister
Brake drum stuck
When this happens what I do is unbolt the wheel cylinder from the backing plate, disconnect the brake line and push it in. This makes the shoes fall apart inro the drum and it should come apart. If its still stuck then the drum must be rusted to the wheel studs so I knock them back on the flange with a brass or lead hammer. Still be careful not to bugger up the threads. HTH -greg
Old Aug 9, 2002 | 07:52 AM
67Stangboy's Avatar
67Stangboy
Brake drum stuck
I don't know for if this applies to your rear end, but I know on some you have to take the axles out to get the drums off. Thats the way it is on my brothers 79 250. I don't know much about the semi-float rear though.
1990 Ford F250, 351, zf 5sp, 4x4,
RS9000 Shocks, Rear air bags
Old Aug 9, 2002 | 08:43 AM
150freak's Avatar
150freak
Brake drum stuck
