Sponsored by: Innova
Box Size
Old Jun 1, 2003 | 01:38 PM
79 posi's Avatar
79 posi
Box Size
Hey,
My sub lists recommended box size of 1.5 cu ft. What are the negatives of using a smaller box....say 1.1 or 1.2? Also, it is listed as 150 rms @ 4ohm, what would be the effects of running @ 120 rms?
Old Jun 1, 2003 | 09:32 PM
optikal illushun's Avatar
optikal illushun
Box Size
it shouldnt matter much, sub output will be a little different but not much. manufactors ususally give a recommened range on box size so u should be fine, average space for a 12" woofer is about 1v3.
also, driving a woofer under the RMS isnt going to hurt it, just be careful to how the gains are set. running it at 120 instead of 150 would just mean the output wont be as loud, but 30w isnt gunna be a dramatic difference. what kinda woofer is it?
Old Jun 2, 2003 | 04:36 AM
luvdeftonz's Avatar
luvdeftonz
Box Size
When you make a box smaller, you make the sub more inefficient. This means you actually need more power. If you're going to "underpower" it, you actually should make the box a tad bigger. However, with a sub whose RMS is only 150, it's probably pretty efficient, regardless of box size. Underpowering a speaker doesn't hurt it, necessarily. Make sure that you don't clip the amp and go crazy with the volume. You can cause thermal failure of the sub if you're irresponsible. I would just try to stick with the manufacturers rec. enclosure size and set my gains accurately.
Old Jun 2, 2003 | 09:04 PM
79 posi's Avatar
79 posi
Box Size
Thanks for the info.
Its just a cheap pioneer 12"....TS 33 or something like that, got on ebay for like 30 bucks.
Old Jun 2, 2003 | 09:50 PM
optikal illushun
Box Size
i had 2 of those running in a .8v3 sealed box and they were fine, had 150w rms going to em and they loved it.
Old Jun 3, 2003 | 02:19 PM
PrPlayboy's Avatar
PrPlayboy
Box Size
Hey op what does .8v3 mean?
.80 cuft vented 3 times? Can you tell i'm not the box expert (yet). Give me time and a few more lesson tho and I'll be a posting guru like you!!!!
Old Jun 3, 2003 | 02:32 PM
luvdeftonz's Avatar
luvdeftonz
Box Size
.8 cubic feet, sealed. There are no vents/slots/ports.
Old Jun 3, 2003 | 04:22 PM
optikal illushun
Box Size
v3=cubic feet
Old Jun 3, 2003 | 06:28 PM
79 posi's Avatar
79 posi
Box Size
i always thought it was ft^3...........must be web talk
Old Jun 3, 2003 | 10:09 PM
optikal illushun
Box Size
eh, does it really matter? i use v3 cuz its easier to find...but anyway, they'll be fine in a 1.2v3 box
Cd4899
6.7L Power Stroke Diesel
Dec 14, 2012 10:54 AM
AndeyHall
May 31, 2011 01:17 PM
bullish4
Aug 19, 2006 07:36 AM
Veeha
Jul 9, 2004 07:42 PM
jclarke2899
16
Feb 15, 2004 08:02 PM
