fe360 fe390 head swap
Old Mar 1, 2013 | 09:27 PM
muddhogg's Avatar
muddhogg
Talking fe360 fe390 head swap
can i replace my 360 heads with 390 performance heads? if so do i need to do anything else?it was bored .30 over with a mild cam -pushrods 750cfm deamon carb-gear drive timeing-headers and soforth.someone told me its just bolt on power.its a 76 f150 .thanks for any advice.ps it only has about 80 or 90 miles on new build
Old Mar 1, 2013 | 09:40 PM
cb_13's Avatar
cb_13
You posted this in the 04-08 forum. I'm sure one of our fine moderators can move it to a forum where you could receive better advice. I know we have a few guys that post in the Missouri forum that know those engines like the backs of their hands and would be glad to help.
Old Mar 1, 2013 | 10:58 PM
Stewart_H's Avatar
Stewart_H
I got it covered.
Moved to the FE & FT Big Block forum.
Stewart
Old Mar 1, 2013 | 11:07 PM
85e150's Avatar
85e150
So you put stock 360 pistons back in it? Down the hole with 8.2 compression? Did you upgrade your valve springs?
The only "390 performance head" that would do you much good with be a 1960 offering with smaller combustion chambers. Good luck finding those. Otherwise, some other 1960s head have slightly small chambers, and some have bigger valves, but larger chambers.
FE Cylinder Head I.D. and Application Chart
Pull your crank and rods and replace with a 390 crank and rods with those new 360 speck pistons, and you'll have about 9.5 compression and some quench in your combustion chambers.
Old Mar 2, 2013 | 11:43 AM
MIKES 68 F100's Avatar
MIKES 68 F100
if you are asking about the edelbrock aluminum yes they will fit .
Old Mar 3, 2013 | 08:49 PM
muddhogg's Avatar
muddhogg
360 to 390 heads
thanks for your time and the information,tis is a big help.bob
decaruby
181
Jan 1, 2020 12:09 AM
6Fastback7
Aug 2, 2013 08:23 AM
mudvillain
19
Mar 11, 2011 04:58 PM
DrFord
18
Aug 28, 2009 12:39 AM
71LTD390
Apr 17, 2004 10:33 AM
