fe360 fe390 head swap
Old 03-01-2013, 09:27 PM
muddhogg's Avatar
muddhogg
muddhogg is offline
Talking fe360 fe390 head swap
can i replace my 360 heads with 390 performance heads? if so do i need to do anything else?it was bored .30 over with a mild cam -pushrods 750cfm deamon carb-gear drive timeing-headers and soforth.someone told me its just bolt on power.its a 76 f150 .thanks for any advice.ps it only has about 80 or 90 miles on new build
Old 03-01-2013, 09:40 PM
cb_13's Avatar
cb_13
cb_13 is offline
You posted this in the 04-08 forum. I'm sure one of our fine moderators can move it to a forum where you could receive better advice. I know we have a few guys that post in the Missouri forum that know those engines like the backs of their hands and would be glad to help.
Old 03-01-2013, 10:58 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
I got it covered.
Moved to the FE & FT Big Block forum.
Stewart
Old 03-01-2013, 11:07 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,720 Likes on 1,405 Posts
So you put stock 360 pistons back in it? Down the hole with 8.2 compression? Did you upgrade your valve springs?
The only "390 performance head" that would do you much good with be a 1960 offering with smaller combustion chambers. Good luck finding those. Otherwise, some other 1960s head have slightly small chambers, and some have bigger valves, but larger chambers.
FE Cylinder Head I.D. and Application Chart
Pull your crank and rods and replace with a 390 crank and rods with those new 360 speck pistons, and you'll have about 9.5 compression and some quench in your combustion chambers.
Old 03-02-2013, 11:43 AM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
if you are asking about the edelbrock aluminum yes they will fit .
Old 03-03-2013, 08:49 PM
muddhogg's Avatar
muddhogg
muddhogg is offline
360 to 390 heads
thanks for your time and the information,tis is a big help.bob
decaruby
181
01-01-2020 12:09 AM
6Fastback7
08-02-2013 08:23 AM
mudvillain
19
03-11-2011 04:58 PM
DrFord
18
08-28-2009 12:39 AM
71LTD390
04-17-2004 10:33 AM
Quick Reply: fe360 fe390 head swap
