ground cable on firewall
Old Mar 1, 2013 | 06:53 PM
FordYoungGun35's Avatar
FordYoungGun35
96 5.0 theres a cable thats bolted to the fire wall on the left side by the ac.. was told it might bolt up to the engine too but im clueless
Old Mar 1, 2013 | 07:41 PM
subford's Avatar
subford
It bolts to the upper intake.
Old Mar 1, 2013 | 07:45 PM
FordYoungGun35
any clue as to where? and what would it cause if its not hooked up?
Old Mar 1, 2013 | 07:57 PM
subford's Avatar
subford
Look at the image above as to where.
As long as you have a good body ground and engine ground it would not matter much.
But if someone only ground the frame this ground wire can burn in two when you try to crank the engine. You do not need the frame grounded anyway if you do not pull a trailer. The Big ground from the battery always goes to the engine block.
columbia1spring
Sep 22, 2017 01:44 AM
newguy399
May 2, 2016 12:05 PM
Phil Woolfson
Jul 15, 2014 02:34 PM
brady struck
Mar 30, 2011 10:22 AM
Dannym
Dec 1, 2008 02:53 PM
