Blown turbo, any one else?
I was towing a heavy load up a hill and got a squealing noise from what sounded like my turbo bearings. The truck was running fine, all temps were normal, fluids were ok. I took the truck to my Ford dealer and he said everything was ok. One week later the truck started producing huge amounts of blue smoke out the exhaust pipe, back to the dealer, blown turbo bearings. The truck has been at the dealer for 3 days so far.
My dealer told me they have been having problems with the turbo screws coming loose due to the vibration of the engine, resulting in the turbo housing warping, which destroyes the bearings.
How common is this problem? Anyone else had similiar failures?
2002 Ford F-350 65,000 miles. Last week my alternator went out, starting to wonder whats next!
I had the same problem in my 1999 F-350. Last year I took it in for something else w/ 76,000 miles and the dealer called me and said the turbo was pretty much gone. He quoted me a price to replace it. Well, then I quoted him a prie of FREE beacuse the motor has a 100k mile warranty. One of the bolts had rattled loose, saidit was a common problem. Needless to say they did it for free and put in a brand new turbo and I never went back to that dealer again. Oh, the problem was my brakes, pulling left. They said it was the ball joints. I took it to another dealer in the area I found out who knew what they were talking about. It was just the rotors. Oh well, live & learn.
Sean, The four bolts referred connect the turbo to the turbo housing plenum. They are above the pedestal which mounts the turbo. They run horizonal and have a torx type head on them. I recently installed a banks housing and two of my bolts were completely backed out, (on opposite sides) however there is a machined male to female fit between the two pieces and almost next to impossible to get out of alignment. Mine used 3/8 box end wrench. Rear are next to impossible to get to. Remove turbo?? Carroll
Carroll,
Thanks I am going to check mine and monitor them. I really don't want have any down time for maintenance even if it is covered by the warranty.
Sean
Sean
