well well... 400 Stroker Kit
Old Jun 1, 2003 | 04:53 AM
GT40man's Avatar
GT40man
look what I found while looking for piston profiles
http://www.strokerkits.com/351___400m.htm
maybe shazam can save some money on his next build.
Old Jun 1, 2003 | 07:30 AM
Brian S's Avatar
Brian S
6.25 rods aren't long enough for a 10.3 " 400 block.
Old Jun 1, 2003 | 02:11 PM
Matts72's Avatar
Matts72
Those numbers are right Brian. or at least last time I checked 400 rods were 6.25" long.
Old Jun 1, 2003 | 04:07 PM
shazam's Avatar
shazam
Last time I checked the 400 rod was 6.580 Long ..........
IN a STOCK 400......
Ya it looks like it would work but 9.5 to 1 won't make it in my world ..
14.5 to 1 is more like it .......
And I think it's a Scat Cast steel Crank Not a Drop forged Steel one like I run .
But then with 9.5 and making it a Street Motor it should work just fine .
Old Jun 2, 2003 | 01:33 AM
Brian S's Avatar
Brian S
Stock 400
10.3 deck
-2.0 1/2 stroke
-6.58 rod
-1.65 piston CH
.070 deck clearance
434 stroker
10.3 deck
-2.1 1/2 stroke
-6.25 rod
-1.88 to 1.94 piston CH (not likely unless it's a custom 351M piston with a smaller .927 pin!)
.070 to .010 deck clearance
9.5 deck
-2.1 1/2 stroke
-6.25 rod
-1.15 piston CH (short, but not uncommon)
0 deck clearance
4.2" crank is most likely a stock iron 400 off set ground with reduced counterweights, 2 or 2.1" Chevy journals.
Old Jun 2, 2003 | 02:18 AM
Brian S's Avatar
Brian S
Elsewhere on the stroker site under crankshafts.
http://www.StrokerKits.com/misc_crankshafts.htm
"4: Ford 400M Nodular iron crankshaft stroked to 434 cubic inch for 351W block------$450.00 plus S & H."
Old Jun 2, 2003 | 03:42 AM
Torque1st's Avatar
Torque1st
Posting Legend
Why don't you guys call the guy and ask him how it all works out rather than arguing about it...
Old Jun 4, 2003 | 05:35 PM
rogue69's Avatar
rogue69
Almost 2000.00 for the kit! Why not just put a 460 in it?
Old Jun 5, 2003 | 08:32 AM
GT40man's Avatar
GT40man
because i already got the 351 4V heads ported.
oops, no i didnt port the heads. yea, thats it, thats the ticket.
Old Jun 5, 2003 | 09:14 PM
shazam's Avatar
shazam
Besides anyone can put a 460 in .. It takes real talent to get a 400 to put out 500 H.p.
Old Jun 6, 2003 | 10:18 AM
rogue69's Avatar
rogue69
"Besides anyone can put a 460 in .. It takes real talent to get a 400 to put out 500 H.p."
And a hell of a lot more $$$$$$$
Old Jun 6, 2003 | 11:41 AM
shazam's Avatar
shazam
Hay I never said it was easy ..
Old Jun 6, 2003 | 02:39 PM
Torque1st's Avatar
Torque1st
Posting Legend
I would just be happy with ~400 HP and 500+ lb-ft of torque from my 400!
Old Jun 22, 2003 | 12:11 PM
rwehrli's Avatar
rwehrli
Actually, it is very easy to make 500 HP with a 400...and not really very expensive. A set of decent factory iron CC 351C-4V quench heads with some work with a die grinder, sanding rolls and common sense...a set of 12.5:1 TRW pistons...a nice solid lifter cam such as the Comp Cams 32-240-4...adjustable valve train and decent, aluminum roller rocker arms and very good valve springs. Stock bottom end with just reconditioned rods and ARP rod bolts, an Edelbrock Torker 4V intake and a 750 vacuum secondary carb with secondary metering plate to metering block conversion...a factory late model electronic ignition with the advanced locked out...and you have a fairly easy 518 HP / 493 TQ with about $1400-1700 into it...plus or minus depending on availability of parts in your area...without a stroker kit and without anything more "special" than buying a used set of 4V heads ($250-300 in most places) and reconditioning them properly and mods for screw-in studs, guideplates and very good springs. If you have to go with a longer set of valves (+.100"), then it will eat up another $250...but it is worth it to get some good Manley stainless, taper stem valves that can take more spring (installed) height. Some good shopping around skills and using eBay, you should be able to trim some fat off of the price tag, too.
Also, I'm fairly sure that "someone" didn't "last time I looked" at the 400-M rod length, since it is 6.580" from the factory. The deck is a nominal 10.3" and a 6.25" rod is only about a quarter inch too short. These rods are longer than factory big block Chevy rods, which are 6.135" with a 9.8" deck...now if the 400-M block just had a 4.180" bore!
A lot of people call the 400-M a "big block" ...partially because it is relatively large internally (dimensions and CID), but also because it (and the 351-M) shares the same bellhousing pattern with the 429/460 BBF. However, its factory cylinder heads are definitely small block in a big way and when combined with a set of 4V heads, you have a 400 with factory valve sizes nearly equal to that of a 454 BBC...at 2.19"/1.71" for the 4V and 2.19"/1.88" for the BBC...in a small block sized package!
The 400-M is certainly the heaviest "small block" Ford, but you can make 430 HP/ 430 TQ with a dual plane, hydraulic flat tappet cam and 10.0:1 compression on pump gas.
...the most expensive part of a 500 HP 400-M is the common sense!
Take Care.
Rob!
Old Jun 23, 2003 | 01:23 AM
Matts72's Avatar
Matts72
recycling thread.
