Squishy Brakes
Old Mar 17, 2013 | 09:59 AM
  #31
bashby's Avatar
bashby
Originally Posted by blacklab1
I had the same problem on my 96 F150. Someone on here suggested removing the big nut on the ABS valve, then remove the spring and replace the nut.
I did and all is well.
Yes, this works the same as bypassing it. There is a accumulator that lets pressure bleed off when the comp senses the rear wheels locking up. Sometimes the valve leaks and fluid always goes into the accumulator. Remove the spring and the accumulator fills with fluid and stays full.
Old Mar 17, 2013 | 10:20 AM
  #32
BigBlockF350's Avatar
BigBlockF350
Okay, thanks. I'll check that out. Did you have to take the valve off to get it out or did you do it with the valve still mounted on the truck?
It might have been different on yours. You may have ABS on all brakes. I'll look at mine.
Old Mar 17, 2013 | 10:38 AM
  #33
blacklab1's Avatar
blacklab1
It's tight, but I got a wrench on it without removing the valve.
Old Mar 17, 2013 | 11:20 AM
  #34
BigBlockF350
Thanks for the response. That makes sense with the spring. That should be pretty much the same as bypassing it. I'll try taking the spring out. If that helps the brake response I may just leave it that way. I feel the need for ABS, I'll replace the unit. If it doesn't help, I'll go elsewhere looking for a solution.
Still want to replace the rubber lines even if that works though. They're old, and it's a good maintenance item to replace to keep everything safe.
Old Mar 17, 2013 | 12:28 PM
  #35
88n94's Avatar
88n94
Originally Posted by BigBlockF350
Yeah, not much happens in the first 3" of brake pedal travel.
If you are stopped with the engine running and you pump the brake pedal about 15 times and then hold it down, will the brake pedal go down a lot less than 3 inches?
Old Mar 17, 2013 | 12:48 PM
  #36
BigBlockF350
Maybe slightly different, but seems pretty much the same. What would that indicate?
Old Mar 17, 2013 | 01:08 PM
  #37
88n94's Avatar
88n94
If after pumping the brake pedal about 15 times and holding it down firmly, the bake pedal would only go down say an inch or a little more, that would be a sign that the rear brake shoes need adjusted tighter. If your brake pedal still goes down nearly 3 inches after doing this you can disregard this.
I know you have adjusted the rear brakes probably a couple times already. It can be real tricky to get them adjusted right, especially with self adjusting brakes that probably aren't working. If you find your pedal does stay up after pumping and holding the brake pedal, I will reply more.
At this point anything is just a guess.
Old Mar 17, 2013 | 04:14 PM
  #38
Tomboy2013's Avatar
Tomboy2013
Had similar issue
I just bought an under cared for 1995 f150 that had "squishy" breaks. We first replaced the master cylinder which didnt help but I'm cool with new parts. Then he went to do the rear adjustment everyone has mentioned and my spring kit was broken. When he replaced the spring kit and bled the new master cylinder, my brakes worked properly. I'm no specialist but this is how it worked for me and far as I'm concerned "squishy" brakes equals almost no brakes.
Old Mar 17, 2013 | 06:55 PM
  #39
BigBlockF350
Okay, I did this and got the pedal a lot harder. It took a lot of pumping, but it really stiffened the pedal up when I pumped it a lot. Also, the pedal was much harder when the parking brake was on.
I'm guessing this means that the rear is really the issue. Are my back brakes most likely worn out, badly adjusted, or what? I've adjusted the ring gear all over the place, and it doesn't really seem to be making a difference.
Guess the thing to do now is take the drums apart. What am I looking for?
Also, I'm picking up some new rubber lines for the front tomorrow, and I'll be ordering the hose for the back. Those may not be the issue, but their all getting really dried out (front ones with a few small cracks, but no leaks) and old, and they need to go.
Old Mar 17, 2013 | 06:58 PM
  #40
BigBlockF350
Well, I don't have "no brakes" because the front discs grip nicely once I press down far enough. I was doing adjustments a few days ago to try to get the back gripping, and the front would lock up well, so I'm not afraid of driving it. I just would like to have it right.
Old Mar 17, 2013 | 08:53 PM
  #41
88n94's Avatar
88n94
It's hard to say how bad the brakes are worn, but they wouldn't be worn so bad that they shouldn't adjust up. That adjuster, which you referred to as the ring gear, will screw completely apart if you have enough space in there. You would have to have badly worn drums and worn out shoes for that to happen.
In my opinion you could choose between two modes of action. Adjust the brakes up so tight you have a heavy drag on the wheel so you can barely turn the wheel, then back the adjuster off just enough to relieve most of the brake drag. Repeat with the other wheel. I know you have tried adjusting them, but this is the only method that works for me.
Method number two, remove the brake drum(s) and see what things look like in there. If badly worn replace the shoes and you may need to have the drums turned(smoothed up). At any rate if you remove the drums, get the self adjusters working. Then when you put the drums back on you can adjust the shoes so so and back the truck up in an open space and keep hitting the brake pedal and the brakes will self adjust tight enough.
Old Mar 17, 2013 | 09:08 PM
  #42
BigBlockF350
Thanks for the reply. I played with both adjusters a lot. Right now, I have them as far as I can turn them to the tight side. I think they'll probably adjust further, but I may have to take the drums apart to be able to get in there and turn them further. When I'm turning them with a flathead screwdriver from the access hole, the gears get harder to turn at a certain point. Still don't have wheel drag that I can feel/hear.
Old Mar 17, 2013 | 10:42 PM
  #43
nebechanezer's Avatar
nebechanezer
If the spring is taken out and the pedal response is improved, does that mean the valve is faulty and if replaced would have the same feel? or is that just bypassing a factory configuration and not diagnosing anything?
Old Mar 18, 2013 | 06:52 AM
  #44
bashby's Avatar
bashby
Yes that would indicate a bad RABS valve.
Old Mar 18, 2013 | 09:55 AM
  #45
ptarno's Avatar
ptarno
i also have an 88 f350 XLT lariat with 4x4 crewcab, longbed and 460ci. i had that same issue except my pedal would go almost to the floor before it would even think about stopping. what cured mine was about 20 minutes of gravity bleeding, and a rear brake adjustment. now my pedal is nice and high, and stop on a dime.
