Sponsored by: Real Truck
tire size
Old Feb 27, 2013 | 08:23 AM
roadkingefi's Avatar
roadkingefi
tire size
i have a 2008 f250 5.4L thinking of going from 275/70r18 to 285/75R18 (33"to 35") how much will this effect my tow capacity i believe i have 373 gears
Old Feb 27, 2013 | 10:32 AM
Sparky04SD's Avatar
Sparky04SD
Of all Super Duty set ups, yours has the smallest motor and worse axle ratio available. This does not mean it's not able to tow, it just means you are marginal for towing. Adding bigger tires will do nothing to help and only hurt it. You're dding a tire that's 9.5% taller and has a higher rolling resistance. It will hurt towing, I expect it to be enough to notice, especially in hilly country where torque multiplication is needed the most. It will also reduce fuel economy empty as well as loaded, probably about 10%.
Old Feb 27, 2013 | 12:00 PM
roadkingefi
thanks I have a 11000lb 5th wheel toy hauler i towed with my 2005 f150 with the heavy payload payload rated to tom 9000lbs she did good but did,nt like the hills lost her last yr in hurricane had a tree fall on us on the way home from work just bought my 2008 250 haven't towed yet couldn't understand how it has the same motor and hp as the 150 but is rater to tow 6000lb more k thanks i will stick with original size tire when i replace old ones
Matt's Lawncare
Feb 9, 2019 03:43 PM
IcutMetl
All Things Towing
Dec 17, 2010 11:23 AM
TamaThumper
All Things Towing
May 5, 2004 08:00 PM
posse977
All Things Towing
Feb 5, 2003 02:06 PM
dan4x4
Aug 13, 2000 08:06 PM
