Flasher location
Old Feb 26, 2013 | 04:36 PM
73f250cummins's Avatar
73f250cummins
Flasher location
Well i think its the flasher, i put led's in my truck and they flashed fast for a while. I didnt really care cause i thought it looked kinda cool, well anyway my left side dosent flash anymore and i bought a new flasher i just cant seem to find it. Anybody know where it might be?
Old Feb 26, 2013 | 04:39 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
It is in the center of the dash. Above the floor hump and below the radio. A select few with VERY skinny arms have been able to contort themselves enough to get it out without pulling the radio and dash, but the rest of us have had to take the dash out. It is actually quite easy to take the dash out...
Look up some of the LED threads in the Excursion forums. Lots of pics of where it is at.
Old Feb 26, 2013 | 05:47 PM
F-250 Super Duty's Avatar
F-250 Super Duty
The fast flash is due to the low current draw of the LED's. The truck thinks you have a burned out light on that side hencing the quick flash. A resistor installed on the wire would solve the quick flash problem. As for the no flash at all......I would start at on of the wires at the light to confirm power is not there and work my way to the flasher.
Old Feb 26, 2013 | 10:36 PM
Poolguy601's Avatar
Poolguy601
Try a heavy duty electronic flasher. It flashes steady by design, not load.
Old Feb 27, 2013 | 06:02 AM
srteach's Avatar
srteach
One bolt to remove the vent tube above the accelerator pedal near the firewall and you can reach up to replace the flasher with any size arm. Takes just a few minutes, rather than removing the radio / dash.
Old Feb 27, 2013 | 08:13 AM
73f250cummins
alright thanks guys for the help.
V10man
Aug 1, 2016 09:50 PM
78f150302
Mar 18, 2013 10:40 AM
Reagan K
2004 - 2008 F150
Nov 8, 2011 09:13 PM
masen2001
Electrical Systems/Wiring
Jul 26, 2000 05:38 PM
