1991 4.0 engine life?
Old May 31, 2003 | 09:43 PM
jcwinger's Avatar
jcwinger
hello, I found a good deal on a explorer, it has a 4.0 v-6 its a 1991. the engine has 160,000 miles on it. is this too high of miles and should I keep looking. I know nothing about these engines, this has snappy power and sounds strong. any advice out there and how many miles do you have????? please help thanx!!!
also this is 4x4 and strait,
Old May 31, 2003 | 09:53 PM
ford_tr_man's Avatar
ford_tr_man
these moter's are VERY relieable they run FOREVER there's many with 200k+ miles on them and 160 k miles is not that much for a 91 theise moter's are very strong id say go for it
i have a 94 xlt 4x4 with 81k run's smooth
Old Jun 1, 2003 | 09:37 PM
dennyge's Avatar
dennyge
I would have to agree. I have a 4.0 Liter in my 96 XLT with 144,000 miles on it. Still running strong. Nothing more than routine maintenance. (Knock wood).
Old Jun 1, 2003 | 11:16 PM
rusty70f100's Avatar
rusty70f100
185,000 miles on stock 4.0L explorer. They run forever. Go for it. Knew a guy that had over 250,000 on one, ran great.
Old Jun 2, 2003 | 07:37 AM
dennyge's Avatar
dennyge
Talked to my father-in-law last night and he said he had over 200,000 on his last Explorer (I think it was a 93) and was still purring. Had to rebuild the tranny, but after that long, who doesn't?
Old Jun 2, 2003 | 12:43 PM
rusty70f100
I haven't had to. Still functioning perfectly.
Old Jun 2, 2003 | 01:17 PM
dennyge's Avatar
dennyge
I can only hope that I am as lucky. Would sure like to get another couple of years out of her. She treats me well on those long bird hunting trips.
Old Jun 2, 2003 | 03:12 PM
Toon's Avatar
Toon
Try to find out how the car has been used, were there many previous owners in a short time, is the engine tuned to the limit or plain standard?
Have the engine checked by a pro for exessive wear, if it sounds fine than go for it.
Greetz, Tony
Old Jun 2, 2003 | 06:14 PM
bobs 93 X's Avatar
bobs 93 X
i have a 93 eb with 180000 purrs like a kitten, check vehicle history especially transmission work that has been done. they are the weak spots.
Old Jun 2, 2003 | 09:19 PM
kev100's Avatar
kev100
I had a '91 Sport and drove it until about 230K miles.
The motor was still running great (actually drove it 600+ miles to the dealer at which I traded it in 2 states away).
However, it was getting to the point that it needed rings or something (I think coolant was beginning to leak into the engine).
However that only started at around 210K. At any rate...the motor always ran great and rarely failed to start instantly.
Old Jun 3, 2003 | 10:33 PM
jbain2's Avatar
jbain2
I have a 92' with 120,000. The engine is great. I have a friend who put over 200,000. The only problem with the old Explorers is the rust. They all have a tendency to rust out along the rear lower side paneling. I replaced the dog legs once already.
Old Jun 6, 2003 | 08:09 AM
MuchToMyDelight's Avatar
MuchToMyDelight
My moms 92 EB 4x4 has 230 thousand, and my uncle's 91 XLT 4x4 has 400+ thousand. The only problems he has had were recently the A/C comp. locked up, and while he had it apart, he decided to change the whining power steeering pump that we all knowand love. The engine runs just fine. It had originally been used for a golf course for something, so he got it for cheap when 100k rolled around. I havent ever seen a Blazer make it that far
Old Jun 6, 2003 | 11:47 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
My 94 Ranger 4.0L has 155,600 one owner miles and runs perfect. Oil has been changed every 3000-3500 miles. I'd drive it anywhere today. A buddy of mine had a 92 Explorer 4.0L and it was traded at 186,000 miles; it was running great but he wanted a newer Explorer was all. There is a post in the Ranger forum titles "miles on your Ranger"; you may want to look at it for more feedback on the 4.0L.
Some people have said that the intake gasket has had problems. Symptoms are vac and coolant leaks. Myself, I'd just put a new one on while the motor was out and access was easy.
Old Jun 17, 2003 | 06:45 PM
mljohnson's Avatar
mljohnson
92' XLT 134,000 miles. Nothing but standard maintenance. Doesn't leak fluids or burn oil. A little rust on the rocker panels.
pilot47
Oct 6, 2015 06:51 PM
Da_Lariat_Chariot
Feb 11, 2015 01:44 PM
tatonka
Nov 3, 2013 07:16 PM
JavaMoose
Bronco II
Sep 12, 2001 01:17 PM
