While I was installing the new carpet I took the opportunity to run a wire and leave it under the rear seats. I had a chance to wire up some more leds I had laying around forever. I had lights under the front passenger area, under the front two seats (for the second row), and the top air vents for a while. The second row lights set it off nice now. Cab lights are next .
Looks good - one of the many things our new Explorer has which I wish my Ex had. Heated steering wheel would be up near the top of that list! Lights are much easier to add though! What kind did you go with?
Heated steering wheel would be nice. Lights are from auto zone. The led's came in a ten pack which could be plugged into a 12v power source and illuminate. Each led had a 4 ft wire lead and a sticky back on it. I cut off the power adapter and hard wired into the lights that come on with the door opened / or dimmer switch.
