Sponsored by: Kumho
Tire wear question
Old Feb 25, 2013 | 09:48 AM
kossford's Avatar
kossford
Tire wear question
Hi im new here and was looking for some info i bought a 02 250 2 months ago love the truck drives great for 130000 miles but the front left steer is making alot of noise and wearing on the inside edge and like its skipping every couple inches so very noisy thought maybe ball joints but a buddy say tire is out of balance truck does not pull left or right and drives straight can you help thanks
Old Mar 4, 2013 | 08:42 PM
79silverstreak's Avatar
79silverstreak
Noise could be a loose caliper. I'd imagine ball joint wear would be consistent around the tire, Ive never seen skipping wear.
Old Mar 4, 2013 | 10:33 PM
crop harvester's Avatar
crop harvester
go see Les Schwabs for a free front end check.
Old Mar 6, 2013 | 05:06 PM
maadman's Avatar
maadman
2X or 4X4? Can you feel any vibration in the steering wheel? If no vibration, then rotate the tires, with new balancing and get the alignment checked ASAP. The noise sounds like wheel bearings or hub (if 4X) going bad. Intermitant wear can be caused by bad (weak) shocks allowing tire to bounce off the pavement while driving. With 130000 miles new shocks would be reasonable and sound investment toward handling and safety.
majkthreads
6.7L Power Stroke Diesel
26
Mar 30, 2015 12:46 PM
High_HP
Jul 30, 2013 05:07 PM
hollerg
May 12, 2009 08:58 PM
joeblow972
Apr 2, 2005 03:52 PM
JRC71
Nov 12, 2003 07:16 PM
