Dead idi
Old Feb 24, 2013 | 06:17 PM
1989f250IDI's Avatar
1989f250IDI
Dead idi
My 1989 f250 7.3 with 228,xxx is now a dead mule. She hit a ditch and flipped 4 or 5 times. I did manage to get it started once tow'd home to move it today but the engine fan didn't sound to well on metal and plastic. Debating on what to do with her
Old Feb 24, 2013 | 06:59 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Ouch! Are you alright???
If it rolled 4 5 times, I imagine it's way beyond repair. Save any good parts if any left, and save drivetrain for future project/use.
Chevy_Eater's Avatar
Chevy_Eater
New cab might be a good start.
You okay?
Old Feb 24, 2013 | 07:32 PM
Dieselexic's Avatar
Dieselexic
Hope you're ok Id save everything and start looking for a 79 stretch long bed.Ron
Old Feb 24, 2013 | 07:51 PM
1989f250IDI
Well the front end can never be fixed or trusted again. The cab roof is now lower than it used to be. The fenders and hood is wrapped tight around the engine but i guess the engine is ok. I am unable to verify how it looks tho. All the glass is busted except for the drivers side window and one slider. As far as drivetrain, the transmition and the rear end is still good. It ripped my drivers side tires plum off the bead and into the fender wells so two rims may possible be bent. I have a concusion, a swollen right thumb, a sore shoulder that can't lift anything at the moment as well as some bruises and many cuts from glass. I am thankful to be alive and i am lucky that i was given the chance of life after this wreck
Old Feb 24, 2013 | 07:56 PM
1989f250IDI
How long can it sit full of diesel before i have to worry about it going bad? I obviously can't work on it for awhile. But the fuel does have diesel kleen in it which is suppose to preserve fuel i think. Im looking to drop the tanks this spring as well as cut the hood apart to get it off and look for a cracked engine.
BigBlockF350's Avatar
BigBlockF350
Wow, that was one awful wreck... Hope you're okay. Save everything. If you don't, you'll probably need it later, haha
Old Feb 24, 2013 | 08:56 PM
Red454sedgwick's Avatar
Red454sedgwick
I've messes with trucks that have been dead for years and the diesel still burned. If you have a simlar truck or have an Idea for a project, keep it around. now it is just costing you space. Don't just pull the engain and throw the rest away. I have on rolled truck that just the cab is left and I still rob part out from under the dash. Its amazing how many trips it can save to the parts store.
Victor Aguilar
May 29, 2024 09:22 PM
mr_wrong_tx
Texas Chapter
Oct 19, 2016 07:57 AM
matconger
Jun 22, 2010 09:28 AM
mantecans
May 8, 2010 07:32 PM
Grumpy Polecat
16
Jul 14, 2004 03:51 PM
