Dually Tow Package
Old Feb 24, 2013 | 04:12 PM
yeomansjon's Avatar
yeomansjon
Dually Tow Package
Hey everyone, I'm looking to buy a 2000 f350 dually crew cab with a 7.3. The truck I'm looking at says it has a tow package which I think is a lower geared rear end. Anyone know if this would be much worse on diesel than the '99 SRW Ext. Cab F250 I had? I was getting 16 with that truck.
Old Feb 24, 2013 | 04:39 PM
hammer65's Avatar
hammer65
There should be a tag on the diff cover, telling you the ratio.
My F250 has the tow package, and still has a 3.73.
I don't know if the dually changed the ratio.
Some one will jump in soon.
Old Feb 24, 2013 | 05:03 PM
mudmaker's Avatar
mudmaker
The tow package does not dictate the ratio. My 99 dually had tow package with 3.73's
Should be able to find out the ratio from the VIN.
Old Feb 24, 2013 | 05:15 PM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1
Same here, I ordered mine with the tow pac and 3.73 gears. The tag on the diff will tell you the ratio. Somebody here posted the codes and will probably see this and post them again. Check your rpms. Mine are about 1500 at 50mph, that will give you an Idea.
Old Feb 24, 2013 | 05:36 PM
Bonanza35's Avatar
Bonanza35
Thats funny, but when I ordered mine, build date 9/98 only 4.10 gears were available with dual rear tires. Maybe the late 99 had 3.73 with dual wheels but not the early.
Chet
Old Feb 24, 2013 | 05:55 PM
stinson 108-1
stinson 108-1
Chet, there are a lot of things that are "funny" with the e99/L99 until you need to replace something. Mine is 2/99.
Jim.
Old Feb 24, 2013 | 06:01 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
my 2000 has 4:10s in the rear but it's also a hand shaker.
Old Feb 24, 2013 | 06:44 PM
Pitcrw6's Avatar
Pitcrw6
I remember when riding in Ed's (baddogkuzz) truck, when doing 62 mph at 2000 rpm's, he said he had 4:10 rear end and his a e99.
Old Feb 24, 2013 | 07:22 PM
Bonanza35's Avatar
Bonanza35
I tried to order the 3.73 rear gears in my e99 and there was know way it would go threw. I ordered in June and it wasn't built till 9/98. I think some of that was the dealer on ordering.
Chet
Old Feb 24, 2013 | 08:04 PM
GEugeneS's Avatar
GEugeneS
On the diff tag the code reads:
1 Plant code
2 Axle ratio
3 Denotes Traction-Lok®
4 Ring gear diameter
5 Build year
6 Build month
7 Build day
Mine reads:
4.10 V2C34 UB
606775-5 LS
On the door jam label it shows “axel” and mine is “F2”. I was told on the forum that F2 is 4:10
Hope that helps.
Old Feb 24, 2013 | 09:25 PM
mudmaker's Avatar
mudmaker
Chet
Might be a regional thing as well. My 99 was a 10/98 build with 3.73 and 6spd. I remember when ordering a 95 we price checked it in Denver and they claimed to not be able to sell us one with 3.55 ratios, regional altitude deal we were told. Ended up ordering it in MT with the 3.55's (same place my 99 came from).
69_bronco
All Things Towing
Feb 24, 2010 05:00 PM
IbewSpark113
Apr 20, 2008 06:50 PM
jws316
6.4L Power Stroke Diesel
Sep 14, 2007 11:22 PM
artj
Nov 19, 2004 04:50 PM
Homerun04
May 21, 2002 07:30 AM
