Subwoofers?
Old Feb 24, 2013 | 03:39 PM
chris10's Avatar
chris10
Subwoofers?
I am wanting to put in some subwoofers in my truck, but I don't know of I'll have to put them under the back seat or behind it. Please help!
Old Feb 24, 2013 | 03:52 PM
BigAlsPSD's Avatar
BigAlsPSD
Which cab configuration do you have?
Crew Cab, you can flip the rear seat brackets, to gain a couple more inches for behind the seat.
If you have center console you can get a stealth box, to fit underneath it, or with the jump seat you could do a shallow 10 or 8 under the seat bottom.
Old Feb 24, 2013 | 04:06 PM
chris10's Avatar
chris10
Well I have a crew cab, but I can't find any boxes that will fit behind the seat
Old Feb 24, 2013 | 04:25 PM
BigAlsPSD's Avatar
BigAlsPSD
Guess it depends on how much boom you want, or whether you would like just the off the shelf boxes.
If you flip the rear seat brackets, you will gain about 4" of depth more. At the sacrifice of leg room.
Or you could run some shallow subs, which cost more, under the rear seat or behind, with an appropriate box for them.
Old Feb 24, 2013 | 05:19 PM
chris10's Avatar
chris10
I want all the boom I can get! What would you suggest on getting?
Old Feb 24, 2013 | 05:43 PM
BigAlsPSD's Avatar
BigAlsPSD
Too personal honestly.
I have a single L5 10 that hits just enough for me these days...maybe I'm getting old, I still like a good crisp sound of a 10 though.
But I have seen 4 L7's behind the seat
Old Feb 24, 2013 | 06:19 PM
chris10's Avatar
chris10
That's about what I was looking for. Also, what head unit and door speakers would you suggest?
Old Feb 24, 2013 | 07:04 PM
BigAlsPSD's Avatar
BigAlsPSD
I'm actually running the JL 5X7 Coax's in the doors and rear, with the one 10, driven by a Kicker single channel, with a Kenwood KIV head unit. Nothing too special but I like the sound.
I actually use to have the cheapo Pioneer Coax's in my old 99 and the sound with those over stock are actually pretty good too.
Old Feb 24, 2013 | 07:50 PM
jkidd_39's Avatar
jkidd_39
http://www.supercrewsound.com/99F250ccbtstrip.html
Try these guys. Ohhh how I miss the thump!
Old Feb 24, 2013 | 08:29 PM
Christof13T's Avatar
Christof13T
I have a downward firing 10" pioneer in a console between two front buckets, and 2 12"s in a box firing up sitting on the rear "tool tray area". Mounted it with a couple hinges so i can pull the pins & remove if i need space for more tools, parts, what have you...
I dont like how big the rear box is... but it was bought, i didnt build it...
Both boxes sealed.
I can hear my system hit from a good 1/4 mile if i chose to turn the dials that high up.
Would like to change up and do a custom box up in the rear/upper corner of the cab... angled to fire down/forward. 2 10's & 2 8's. The 12's are too slow for metal/industrial...
Old Feb 24, 2013 | 08:34 PM
Josh88Ford's Avatar
Josh88Ford
I have a cc. I have 2-10" mtx thin line subs and a 1200 watt jl amp in the center of the box. Built my own box to put behind the rear seat. These were the only subs I could find to fit. Hence the name "thinlines".
I would suggest getting decent rear speakers, because the stock ones are junk and get muffled when you turn it way up. Unless you can run the subs separately from the other speakers from the cd player
Old Feb 24, 2013 | 09:38 PM
MTDewX's Avatar
MTDewX
I had a CC, and a buddy that was in the business built me a custom box for a shallow 10. (clarion I think) and an old Roxford amp I put under the passanger seat. it was just right. left it in when I sold the truck.
the box was a little small from suggested specs. but worked for me. nothing special.
guess you could get a second box on each side. I just had one.
Old Feb 24, 2013 | 09:53 PM
JOHN2001's Avatar
JOHN2001
I don't remember who it was but someone here lifted there rear seat not for subs but so his kids could see ahead of them driving down the road. If I recall right he used 3x2" box tubing. Hope that helps if you want them under the seat
Old Feb 24, 2013 | 10:38 PM
69Cobra's Avatar
69Cobra
Originally Posted by jkidd_39
Ford F-250/F-350 Supercrew Cab 99-07 Triple BTS Subwoofer Box
Hummm That's interesting... I've been wondering the same thing. I've got a CC with a console and I've heard about the box that goes in the console but I don't want to give up that space. This box here looks like a good option. Does anyone have any personal experiences with it?
Old Feb 25, 2013 | 08:55 PM
rhodester's Avatar
rhodester
Chris,
I've got two kicker comp vr 12's in a custom sealed box behind my back seat (its a CC). I'm not sure if you're interested or where you are located but I'd be willing to sell the setup to you. The amp went out which coincided nicely with the birth of my first child so I don't really see the need to replace the amp and have the back seat shake my child like crazy. I'll take pics of the setup and details about how it's installed in case you just want to do something similar for yourself.
-rhodester
