Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2001 Escape
Old Feb 24, 2013 | 11:43 AM
Vinford's Avatar
Vinford
2001 Escape
I had to go 300 miles to rescue the wife and her Escape yesterday.
She phoned and said it had no power, she checked all fluids etc and kept driving , while I set out with the trailer to meet her.
She kept coming and we met half way. I opened the hood and hear what sounds like a vacum leak or something.
I see this round thing near the dipstick has the side of it blown out.
Can anyone tell me what it is and why it might have a hole in it?
It had hot exhaust coming out the hole.
Could the cat be plugged and it back pressured out through this thing?
Old Feb 24, 2013 | 03:46 PM
pauloz's Avatar
pauloz
One of us here is a dealer parts person. Looks like a back pressure transducer/BPT. Heat (from EGR system) might have caused the hole.
Old Feb 24, 2013 | 04:17 PM
projectSHO89's Avatar
projectSHO89
EGR valve, looks like.
Old Feb 24, 2013 | 04:37 PM
pauloz's Avatar
pauloz
on fordparts.com, the egr is part #9d475 for an 01 escape
Old Feb 24, 2013 | 05:46 PM
scott91370's Avatar
scott91370
EGR valve, but how did that happen...
From what it looks like the entire crack is fresh, all if the metal is clean- no black around it.
Old Feb 24, 2013 | 11:36 PM
Vinford's Avatar
Vinford
that was my question , why?
Looks like a clean break , she was just driving down the road and it happened.
Old Feb 24, 2013 | 11:46 PM
2006lariat's Avatar
2006lariat
The Cat's are probably plugged. Escapes are notorious for this. The sad truth, unless it is in phenominal shape, it is too expensive to fix the right way. I hammered the cat's on my wifes.
I know of several with this problem, some with low miles, While other's never have it, but either way 3 ppl I work with have also hollowed the big cat. The 2 on the header's (if a V6) are almost impossible to gut, and I am sure the idiot light's from the O2 sensor's would be on.
Old Feb 25, 2013 | 08:17 AM
tomw's Avatar
tomw
If the cats are plugged, the secondary O2 sensors, after the cat, should be telling a tale via SES or CEL lights. I would temporarily install a pressure gauge into the upstream O2 sensor plug, and measure the pressure, or, remove the O2s, shielding anything that could melt or catch fire, and run the engine to see if it had power again. It takes a little while for back pressure to rise, so you have a little time to check for 'power' even with everything in place. IOW, if it works for a few minutes before getting gutless, it points more to backpressure, likely caused by melted cats.
If it was maintained with spark plugs replaced at reasonable intervals, the cat should not give up the ghost. It must have been fed the wrong stuff to kill it.
Aftermarket cats are available at about 1/2 the cost of factory. If in CA, they must be CARB approved or you won't pass SMOG check. I bet there are a buncha Escape types being exported from CA to the rest of the US {and world} because of cat failure and OEM replacement cost.
tom
Old Feb 28, 2013 | 09:55 PM
Vinford's Avatar
Vinford
So we decided it was the cats.
I cut the big one out and that helped somewhat.
I put a piece of pipe in where it used to be.
I was quoted $2200 to change the mainifold ones.
Old Mar 3, 2013 | 02:08 PM
tcesni's Avatar
tcesni
The EGR on my wife's 02 blew out this week and it looks just like the one in the photo earlier in this thread. I've been suspicious of her cats for some time because the car is down on power. I really want her to replace the car, for some reason after 205K she really likes it. Now I gotta figure out what to do with it. I HATE working on exhaust systems.
Old Mar 3, 2013 | 02:42 PM
tomw's Avatar
tomw
tcesni:I HATE working on exhaust systems.
Me too. Too much rust on the fasteners, and then you have to use muscle to break them free, which of course means they let go with a snap, and your fingers run into whatever happens to be nearby. Always.
The manifold nuts & studs on the 3.0 are even rusted here in GA to where I don't know if they'll come off without either breaking the studs or backing them out of the cylinder head. The engine ticks for a few minutes after it is started, making me think the exhaust manifold gaskets need some attention, but I have been procrastinating as you don't hear it at all when inside the vehicle.
tom
vossenmatt
6.7L Power Stroke Diesel
32
Sep 23, 2018 05:20 PM
Wyatt Griffin
1997 - 2003 F150
Oct 23, 2017 09:51 PM
cstephens
23
Mar 1, 2014 09:17 PM
slowmans
Jul 11, 2007 05:42 PM
mustangman33
Oct 19, 2005 04:33 PM
