03 Expy, tranny/electrical problem
Old Feb 23, 2013 | 04:35 PM
grantpage's Avatar
grantpage
B1602 PATS Recieved Invalid FMT/Key CD
P0753 Shift Solenoid A Electrical
P0758 Shift Solenoid B Electrical
P0740 Torque Converter Clutch Fault
P1760 Pressure Control Solenoid A Short
p0305 Cylinder 5 misfire Detected
P0316 Engine misfire Detected on Startup
The Trans will unlock while driveing for a few seconds then lock back up and drive fine, it seems to be worse over the past couple days. It is no different cold or hot. I also noticed the head lights dim and the voltage on my scanner drops to around 12 volts when the trans disengages. When it is not acting up it drives and shifts perfect.
I have checked a few grounds that were visible and cleaned battery connections. There has to be a wire harness or ground that I am missing some where that is bad??
The misfire code has been fixed, not related.
Old Feb 23, 2013 | 05:36 PM
Franklin2's Avatar
Franklin2
I would check the tranny wiring harness. I believe it runs down behind the back of the engine, and it is known for having problems, even catching fire once in awhile.
Old Feb 23, 2013 | 07:37 PM
grantpage's Avatar
grantpage
Ok, I will try to get it on a lift and check that, I followed it up as far as I could while laying in the garage.
The truck actually cut off today while driving about 30 mph, so if it is a short I imagine it is a pretty bad one.
nick_ct_203
Dec 31, 2015 03:45 PM
brolandscape
Oct 30, 2015 02:30 PM
grantpage
May 6, 2013 06:22 PM
rvoyles
Aug 30, 2012 11:59 AM
hood
1997 - 2003 F150
Sep 9, 2004 08:24 AM
