Help!
Old May 31, 2003 | 05:10 PM
imax's Avatar
imax
Help!
Just Bought 94 Aerostar XL Sport & 96 Windstar. First fords for my wife and I. Already a problem. Perhaps someone could help me figure it out.
Test drove them both on Monday. Both drove fine. Picked them up yesterday and drove 1 mile to a gas station. Everything was fine. Filled up the tanks and proceeded home. On the way my 94 Aerostar did not want to go. The engine is reving but it seems like the transmission was not engaging. It would take 30 seconds before it would shift into the next gear.
Today I changed the filter and fluid in the tranny. Looked old but no metal was found in the pan. The problem is still there. Spoke to the guy who rebuilt my Astro Vans tranny last year and he said it does not sound like the tranmission, especially since there was no metal found in the pan. Said it could be the modulator or something else. Also told me that qa rebuilt for this would be $795. Reasonable I thought.
Anyway, anybody ever experience anything like this. Lack of power and the transmission not shifting normally. I can put the pedal to the floor and I'm lucky if I hit 20 mph in 30 seconds. Any help would be appreciated.
1994 Aerostar 3.0 engine A4ld Transmission
Old May 31, 2003 | 10:35 PM
Torque1st's Avatar
Torque1st
Posting Legend
Help!
I have moved your post down here to the tranny forum for some answers.
If a modulator is bad it would not require a whole rebuild.
DO NOT DRIVE your vehicle in this condition! It will quickly burn up the transmission and wear out all of the clutches and bands.
Old Jun 1, 2003 | 12:04 AM
mrshorty's Avatar
mrshorty
Help!
It seems to me I've heard of this just after replacing the filter on the A4LD. If you reuse the old o-rings on the filter, or forget them, or they don't get seated right, then the transmission pump doesn't pick up any fluid and you don't go. When I did the filter on my explorer, there was a little piece of paper in the box that even warned against reusing the filter retaining bolts, and making sure that you use the proper length bolt and spacer.
Not sure if it's the cause of your problem, but it might be worth looking into.
