Removing the dash pad
Old May 31, 2003 | 01:35 PM
OldBlue67's Avatar
OldBlue67
I've been trying to remove the ugly excuse for a dash pad that adorns my truck, but its puting up a fight. First- how many bolts are holding this thing on? I can't help but think I'm missing one. and Second- is it glued to the actual dash, or is there just some trick to getting it off? cause even the places that [i]seem[\i] entirely unattatched refuse to pull off even a bit Maybe I'm making this harder than it needs to be?
Old May 31, 2003 | 01:55 PM
LBell101's Avatar
LBell101
There are about 6 nuts coming down through the top of the dash. About in the middle of the pad. Then there are another 5 to 7 coming through the front edge of the dash. That's it, no glue. But the studs can kinda hold in on.
Larry
www.larryscars.com
Old May 31, 2003 | 02:28 PM
Ohio Bill's Avatar
Ohio Bill
There are 6 nuts along the leading edge of the dash. There are 8 under the top of the dash. On my 72, some of the nuts (under the top of the dash) were serving double-duty as a way to hold a plastic wire-loom support under the dash. I missed it at first and couldn't figure out why the dash wasn't coming out.
Ohio Bill
Old May 31, 2003 | 03:14 PM
CACWBY's Avatar
CACWBY
This can be done, and then holes filled, and dash painted, but you might be better off with a new "cap" that fits right over existing. I have painted, because I really wanted it.
Old May 31, 2003 | 07:44 PM
jor's Avatar
jor
It's not glued but it is probably stuck on like mine was. It will leave some residue but it cleans right off with soap and water. When you pull it off, be sure and lift up on the windshield side (front) first until the bolts clear the metal dash. Then pull straight back to you. This will keep the leading edge bolts from scratching up you nice painted metal dash.
jor
Old Jun 1, 2003 | 02:07 PM
Matt67's Avatar
Matt67
Yeah, my dash pad was cracked too heck and I decided to take it off. I was plesantly suprised when I found the beautifully painted dash that lay below. The semetrically placed holes in the dash are a lot better than the mess of cracks in my opinion. Maybe I'll fill in the holes one day, but for now I don't want to mess up the paint job.
Old Jun 1, 2003 | 04:40 PM
LBell101's Avatar
LBell101
I just finished covering my dash completely in vinyl. I think it looks really nice. I ended up with a few small pull marks near the door edges but it's no worse than pulls I've seen in new cars with leather covered dashes. Just another option.
Larry
www.larryscars.com
Old Jun 1, 2003 | 09:59 PM
CACWBY's Avatar
CACWBY
Man Oh Man Ibell you is the Man!
I can't believe it- I haven't even looked at all the cars and I'm wiped out.
I like the plans you have for the '67, you'll dig the AOD. I'm looking forward to seeing a good pix of the interior when done - do the top those seats come up into the window?
However, your truck e mailed me (a PM) and said it was very sad that you weren't lowering it!
I'll get back to your site when I recover, I can not imagine what it must be like to have the shop and capability to do all this. I'm in awe.
Old Jun 2, 2003 | 11:14 AM
fordification's Avatar
fordification
And just when you think you've got all the nuts, there always seems to be another hiding. The studs tend to bind in the sheet metal sometimes, just pry.
Old Jun 2, 2003 | 09:56 PM
LBell101's Avatar
LBell101
Thanks for the good words Trev!
Actually, I've been impressed by your project for some time now. As a matter of fact, some key decisions were made because of your project. The success of your AOD helped me to go that route. I too am a 'low rider' type. But seeing the difficulties you have gone through made me decide to stick with the stock geometry. Maybe someday...
The headrests on the seats do come up into the rear window. I have it engineered not to hit, I think. They looked fine when temporarily installed.
Thanks!
Larry
www.larryscars.com
Old Jun 3, 2003 | 11:30 PM
Wagion's Avatar
Wagion
What wold be a resonable price for an original dash pad off a 1972 f series?
Old Jun 4, 2003 | 03:44 PM
OldBlue67's Avatar
OldBlue67
They're for sale @ MotorHaven for over $350 for the actual pad. You can get caps for them off of ebay for about $75 or less if you're lucky.
Old Jun 4, 2003 | 04:15 PM
fordification
Wow. I've replaced mine twice for like $10 each from the local wreckers.
Old Jun 5, 2003 | 11:53 AM
OldBlue67's Avatar
OldBlue67
Well yes there is that option But decent ones can be nearly impossible to find. Most that I've seen are as bad as mine or worse (and mines pretty bad off!) I saw one not too long ago that was not entirely crappy, the part over the speaker was broken off around the edges, but that was all. I thought about it, it was the best I've ever seen, but decided against it. Of course, me not knowing how to get the dang thing off at the time didn't have anything to do with that decision
Old Jun 6, 2003 | 08:45 AM
fordification
For some reason there's been alot of mint dashes around here. Mines flawless except for very light fading that I think armor all could fix.
