Morning all, just went through another alt, 3rd in 5 months, checked all wiring that i know of but dont know what is causing. 2 new batts
Any suggestions?
Is it frying as in burning the windings on the stator? If so you either have high resistance in the wire going from the alternator OR your truck is drawing more than the alternator is capable of putting out.
What alternator are you getting? What is the amp rating?
Are you running anything aftermarket that has a high draw?
RIght belt? Too tight? Lined up correctly?
What is it that makes you think it is frying or what are the symptoms?
It is the 125a, and yes the windings go in them. I do run 1 sub and 2 amps, have hydronic heater and back up cam in stereo
I tried a napa one this time and its only 1 month old and went on a 80km drive got back in and read like 8 vand had to get boost.
On way home after about 1/2 od driving the amps would hold at the lights but when I got home and started turning stuff on/off, you could see volts going up and down.
As far as too tight , how would I know? It is lined up correctly
also how do you put description of truck under your name? That way atleast people can see what the truck is and whats been done
If too tight, it could pull too much and cause bearing failure but you said the windings are getting fried so cancel that.
Originally Posted by boondocks101
also how do you put description of truck under your name? That way at least people can see what the truck is and whats been done
That is your signature. WHen you are in the forums, look at the top left just above the thread listings and click on USER CP. Then down the left side you can click on SIGNATURE and create one.
Oversize batteries don't mean jack if you can't charge them as fast as they're draining. All that does for you is give you a large reserve when the alt lets go.
2 500 watt amps would equate to a draw of ~82 amps all by themselves. Couple that with the rest of the electronics equipment in the truck and you're definitely pushing over what your alternator is capable of.
Originally Posted by BillyBob69
125amps?
I thought our trucks are rated for 165amps factory with 185amps being the upgrade?
Hopefully someone will chime in on that.
Depending on year and alternator. The trucks that had the 3G Alternator had 130 amp alternators, whereas the ones with the 6G style were 110 amps. Ford never offered a 165 amp alternator. They DID however offer a 140 amp for the ambulance packages. They also offered dual alternator for the ambulances as well.
with 2 500 watt amps you have the potental of drawing around 84 amps there alone...
If you regularly crank the **** to 11 then you are drawing close to 84 amps on the stereo alone, add in the IDM, fuel pump,exterior lighting, head unit etc and you are over the 110AMP alternator limit....
end result...I bet you need a bigger alternator
Thx for the info guys, still fairly new to diesels. What options are there for alts? or do I have to consider dual? Is there much involved in putting duals in?
