1978 - 1996 Big Bronco
No Spark ?
Old May 31, 2003 | 09:22 AM
Snook's Avatar
Snook
No Spark ?
After runing all tests discribed on the Haynes and Chilton on my 1987 Bronco TFI-IV,EEC-IV. and replacing the Distributor, I still don't have spark,the coil shows that gets the 12volts and the wiring tests ok. I'm down on asumming that the ECU on the inside firewall must be the problem.
My question is if I change this Computer unit from one found at a junk yard or a remanufactured one would I have to take it to be reprogrammed ?
Thank you
Old May 31, 2003 | 03:47 PM
greystreak92's Avatar
greystreak92
No Spark ?
So you have replaced the the control module on the distributor as well? EEC-IV should have the control module on the distributor if I recall correctly. Ford moved it around '91-'92 because it was prone to heat related failure mounted on the distributor but in '87 I think it was still on the distributor. As far as replacing the main computer, as I unsderstand it, making absolutely certain that you have replaced it with the EXACT same part number should allow you to simply swap one for the other. Don't rely on just my knowledge though. Wait and see who else responds and what they have to say.
Old May 31, 2003 | 09:52 PM
c96drumm's Avatar
c96drumm
No Spark ?
Did you do a resistance check on the coil? Getting 12v into the coil doesn't mean anything is coming out of it.
Old Jun 1, 2003 | 10:49 AM
Snook's Avatar
Snook
No Spark ?
Yes I did that too, I would imagine if my timing chain broke I would
Still have spark...Correct?.
Old Jun 1, 2003 | 12:39 PM
c96drumm's Avatar
c96drumm
No Spark ?
I think if the timing chain broke, the distributor wouldn't turn because it's driven off the camshaft, so no spark.
Old Jun 1, 2003 | 12:44 PM
Bob Ayers's Avatar
Bob Ayers
No Spark ?
You are exactly right, if the timing chain broke, there would be
no spark. If the teeth on the distributor drive gear wore off,
there wouldn't be any spark either. The best way to check
both of these conditions, is to see if the rotor is turning
(remove the distributor cap) when you crank the engine...
Old Jun 1, 2003 | 04:04 PM
Snook's Avatar
Snook
No Spark ?
Are you guys sure ? I thought that this 302 runs the distributor with the oil pump, and then maybe the oil pump is run by the camshaft all together, who knows.
Regardless I do see that the rotor turns when I crank.
I think I'm one step closer to get brave and try to find a computer replacement.
I don't like to see my Bronco growing weeds, she is been good to me!
Thank you
Old Jun 1, 2003 | 04:14 PM
Bob Ayers's Avatar
Bob Ayers
No Spark ?
Yes, the camshaft drives the distributor, which then drives the
oil pump.
Old Jun 1, 2003 | 06:18 PM
tom2131968's Avatar
tom2131968
No Spark ?
do you get spark when the ignition key is turned all the way to the start not run position??
tt
Old Jun 1, 2003 | 09:19 PM
c96drumm's Avatar
c96drumm
No Spark ?
Yes.
Old Jun 1, 2003 | 09:26 PM
tom2131968's Avatar
tom2131968
No Spark ?
I had the same problem...a module needs to be replaced. Might be the TFI one if I recall correctly. I can call the mechanic that did it for me and see if he remembers which one. I lost my mind trying to figutre it out. Email me @ tom2131@stny.rr.com
bozo4ford
1983 - 2012 Ranger & B-Series
Oct 6, 2012 07:47 AM
davedalman
Mar 23, 2011 08:50 PM
timbarr
Aug 4, 2003 07:55 PM
