Fuel pressure gauge for Tech Folder?
Old Oct 19, 2013 | 08:45 PM
Fandini's Avatar
Fandini
What about the Edge Insight pressure sensor. Anybody use those and like it?
Old Oct 20, 2013 | 03:16 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
The Edge pressure sending unit is an identical install for the hardware, the difference is that the wiring part is easier because it comes with plugs pre-assembled and it just clicks together. I think Bpounds has his set up to run that way, it just shows up as another PID you can choose from the list. I chose to put an Isspro gauge into the dash cover instead of buying the Edge setup to run it into my Insight CTS because cost for the Edge setup was waaaaay more than I wanted to spend. Plus there is a matching EGT gauge in the dash panel on the other side of the steering column, the cost savings for both of them was significant.
Old Mar 2, 2014 | 07:27 PM
texastech_diesel
Token Redneck
Fix broken link for the adapter/ extension hose:
Driven Diesel 6.0L Fuel Pressure Adapter
DieselVol
Aug 1, 2012 08:33 PM
John Diem
May 30, 2012 01:55 PM
reeder65
Jan 13, 2012 03:21 AM
whitesdford
22
Oct 23, 2009 05:25 PM
paintdl
Jul 16, 2007 06:54 PM
