96 f150 no heat what the heck is going on!
Old 02-24-2013, 01:04 AM
timbersteel's Avatar
timbersteel
timbersteel is offline
Another thought, was the t-stat tested before installing it? I always boil some water in a pot with it in and with my Craftsman DVOM/thermocouple, verify it's opening temp and closing temp.
Old 02-26-2013, 06:29 PM
badger122068's Avatar
badger122068
badger122068 is offline
UPDATE ON NO HEAT
It turns out my bargain brand t'stat was stuck OPEN. Replaced with a good quality one. NOW have high temp readings on dash guage.
Old 09-08-2014, 11:32 PM
Brokewhiteguy's Avatar
Brokewhiteguy
Brokewhiteguy is offline
Originally Posted by Conanski
Do you get less heat when accelerating or does it shift between floor and defrost? If so you have a broken vacuum line on the diverter door or inside the dash.
My AC is doing this - I dont think I have heat period. Gonna go in and check the heater core.. Thank for the heads up on vacuum lines. Completely forgot they were back there
Old 09-14-2014, 10:14 AM
cryptyx's Avatar
cryptyx
cryptyx is offline
Above the cab fan under the hood( passenger side) there is a white vac line that goes to the controls, now I'm not sure if this may help but it's worth checking out. My truck has the same issue and this is the only thing I've came across that looked troubling. Problem is I haven't driven my truck since I bought it so I can't be for sure. I know these 9gens have an infamous problem with this exact vac line tho.
10actuxedo
1997 - 2003 F150
11-16-2014 07:55 AM
RWV1991
1997 - 2003 F150
01-28-2012 12:14 AM
Zero Obliquity
15
09-22-2007 02:19 PM
atterz8170
02-07-2007 07:50 AM
Gus00
12-21-2005 10:22 PM
Quick Reply: 96 f150 no heat what the heck is going on!
