Bad vibration
Old Feb 17, 2013 | 08:15 PM
BossFan's Avatar
BossFan
Bad vibration
Whenever I take my F250 out on the highway, it develops a very bad vibration from about 45-65 MPH. If I get out of the gas, I hear/feel a big 'clunk'. Ironically, it seems to smooth out above 65 MPH, if that makes any sense. I did some reading here and it seems like the carrier bearing or u-joints could be the cause. How do I check for excessive play? Just grab the driveshaft and see if it moves back and forth?
Also, I've never even seen a carrier bearing, but I'm assuming that since I feel this vibration when I am in 2WD, the problem is likely to be in the rear driveshaft. Is that correct? Could bad u-joints/carrier bearing up front still cause issues even when I'm not in 4WD?. Sorry if this is a rudimentary question. This is my first 4WD vehicle.
Thanks
Old Feb 17, 2013 | 08:22 PM
xkpsanit's Avatar
xkpsanit
Rpms sound like carrier bearing, except for the clunk. ??? Grab the shaft adjacent to the bearing and look for deflection
Old Feb 17, 2013 | 08:45 PM
ShaneNP123's Avatar
ShaneNP123
Typical symptoms of a very worn U-joint.
Old Feb 17, 2013 | 09:33 PM
montana_highboy's Avatar
montana_highboy
Was this vibration always present or just appear out of the blue? sounds like driveshaft out of phase and/or a bad U-joint.
Old Feb 18, 2013 | 12:03 PM
BossFan's Avatar
BossFan
It may have always been there. I rarely drive the truck on the highway, but have noticed it the past couple of weekends.
What does a 'driveshaft out of phase' mean?
Old Feb 18, 2013 | 12:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
2WD: Between the front coupling shaft and rear driveshaft is the center support. Consists of a sealed bearing, large U shaped rubber support, bracket, shims.
Bearing wears causing a howl. Rubber support disintigrates causing a vibration. Replace center support and all three U-joints.
The center slip yoke needs to be greased. When splines dry out, slip yoke scores, howls like a stuck pig.
Old Feb 18, 2013 | 12:26 PM
armstrongfordtrucks's Avatar
armstrongfordtrucks
no carrier bearing in 4X4
Old Feb 18, 2013 | 01:00 PM
NumberDummy
Correct, but if you read the first paragraph, there's not a peep inre to 4WD.
Should have said 1975 F250 4WD "up front" not in 2nd paragraph.
Old Feb 18, 2013 | 01:12 PM
montana_highboy
The yokes need to be parallel to each other, if one's 90 degrees out it will cause vibration issues with the driveline.
The 78/79 4X4 Supercabs and 4X4 Crewcabs have carrier bearings.
Old Feb 18, 2013 | 05:08 PM
BossFan's Avatar
BossFan
Thanks for all the feedback. Sorry for not pointing out up front that this was a 4X4 truck. My apologies for any confusion.
Do the 2WD trucks have a carrier bearing because the driveshafts are longer? Just curious.
Old Feb 18, 2013 | 07:21 PM
tbear853's Avatar
tbear853
There is in the rear shaft of my '77 4X4 .... as well as 3 U-joints.
Maybe not his '75 though.
Old Feb 19, 2013 | 08:51 AM
BossFan's Avatar
BossFan
Mine's a '78, not '75. Not sure if that makes a difference.
Old Feb 19, 2013 | 03:06 PM
The John's Avatar
The John
I had a similar issue with my 77 (2wd super cab), but I had a vibration from about 35-55.
The problem was fixed after replacing the U-joints, Carrier bearing and having the drive shaft balanced and checked for condition.
Hope this helps!
Old Feb 20, 2013 | 11:39 AM
BossFan's Avatar
BossFan
Definitely going to climb under truck this weekend.
This is probably a stupid question, but when you have a 4X4 but are in 2WD mode, does the front driveshaft still spin?
Trying to decide if I should just pull both driveshafts and have the u-joints replaced and have them balanced.
Old Feb 20, 2013 | 12:15 PM
wilcam47's Avatar
wilcam47
I believe the axle shafts will move if the hubs are locked in but not from the gear box to the axle. If the hubs arent locked it shouldnt move... If you have the cash do them all at once. Or if you use the 4x4 in mud a lot I would definitely change them all. I need to change mine but I dont have the cash
