low oil pressure?
Old Feb 16, 2013 | 06:39 PM
adamkat22's Avatar
adamkat22
low oil pressure?
stupid question...but assuming my oil level is ok but the oil gauge reads on the low end of normal (or just below 'normal') what is that an indication of...or is this just another gauge on this van that isn't that accurate...
thanks.
Old Feb 16, 2013 | 06:50 PM
Red454sedgwick's Avatar
Red454sedgwick
I would check it with a machainal gauge. They make a tool to check oil pressure that is worth the peace of mind My 87 has been that way for a year and a half. If you are low on oil down to 2 quts. the gauge will bounce not run low.
Try changeing the sending unit
Change the oil and filter
I run lucas in everything
If it is louder than normal you got issuses or ticking
My grandfather had trubble with the gear spinnig on the shaft of the oil pump in his 6.9, but I don't know if that is a comman problem or not.
Old Feb 16, 2013 | 06:52 PM
hairyboxnoogle's Avatar
hairyboxnoogle
My first assumption would be that its indicating a tired sending unit.
Best to check with a mechanical if you can and if it says youre good, grab a new sending unit or gauge.
Old Feb 16, 2013 | 10:19 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I'd install a new real gauge. Gauges in these trucks are useless. Even worst in the 91 and older vans.
fclanton
1997 - 2003 F150
Feb 12, 2015 05:22 PM
BigBlue92
Apr 7, 2011 05:04 PM
nick_8403
1978 - 1996 Big Bronco
Jan 10, 2009 01:02 AM
imfinethanx
Modular V8 (4.6L, 5.4L)
Jan 18, 2008 12:02 AM
Kijutsu
1983 - 2012 Ranger & B-Series
Sep 1, 2005 07:42 PM
