Power Lock Question!!
Old Feb 16, 2013 | 01:30 PM
olympicwineshop's Avatar
olympicwineshop
1992 F150XLT. The power door lock motor spins when I push the button, but the lock does not move. (drivers only) Key will unlock and passenger works fine. Is there a mechanical connection that's broken?
Old Feb 16, 2013 | 01:37 PM
White 97 xlt's Avatar
White 97 xlt
More than likely.. You will have to open up the door and see what is loose or broken.. I can't see it from here...
Old Feb 16, 2013 | 05:37 PM
skyfox10's Avatar
skyfox10
what do you mean "motor spins". I think those are solenoids. Is it making a sound like there is a motor in there to make you think it's spinning?
Old Feb 16, 2013 | 05:54 PM
olympicwineshop
power lock question
Yes, makes a pretty loud whirring sound in the door.
Old Feb 17, 2013 | 08:12 PM
skyfox10's Avatar
skyfox10
I'm not really sure why it would be making a sound like that. I thought the actuators on these trucks were solenoid type. If it does happen to be the motor type, then the actuator must have an internal break so that the motor is not turning the rotary motion into linear motion. I don't know if people can repair those or not. I'd check rockauto for a replacement.
It should be one of these in there.
Ford F150 Truck Door Lock Actuator - AM Autoparts
Old Feb 17, 2013 | 10:44 PM
Xclimation's Avatar
Xclimation
I had a similar problem.
See if this thread might help:
https://www.ford-trucks.com/forums/7...-help-plz.html
rosey123
Feb 1, 2010 07:23 PM
MJScore
20
Jun 4, 2009 04:09 PM
FoxyFord83
1997 - 2003 F150
Apr 8, 2005 01:24 PM
rmilchman
Apr 2, 2005 07:37 PM
MJB
Bronco II
13
Jan 3, 2004 10:05 AM
