Clunk!
Old May 30, 2003 | 08:19 PM
oregon250's Avatar
oregon250
Angry Clunk!
1993 F250 4X4 460/E4OD H.D.
I just replaced my front brakes, and thinking that the clunk and thump I would go through when I braked previously would be gone, I was highly disappointed.
I thought that it was from a out of round rotor but nope. Still there, if I turn hard to the right I get a clunk on the drivers side, only when when going forward.
When driving I get a vibration in front drivers side and when I apply the brakes easy if bounces, push the brakes hard it goes away.
The calipers appeared fine and the hardware is all new, any ideas please!
Geoff
Old May 31, 2003 | 04:15 AM
wtrbkt's Avatar
wtrbkt
Cool Clunk!
Check your motor mounts on both sides. It's hard to see if the rubber has separated so put a 2X6 under the oil pan and jack up one side about 2 inches and check that mount then the other side. If one or bot are bad they are pretty easy to replace.
Old May 31, 2003 | 06:28 AM
shotgun's Avatar
shotgun
Clunk!
Check the radius arm bushings also if you have the TTB. If the bushing is shot it's a good source of clunk. If it is your engine mount get a good one from Ford. AutoZone mounts blow...
Old May 31, 2003 | 09:36 AM
eckart's Avatar
eckart
Clunk!
Also check your your ball joints and tierod ends for play. I just replaced ball joints on my truck and the clunk it did when you hit the brakes and light brake shudder disapeared.
Old Jun 2, 2003 | 05:22 PM
oregon250's Avatar
oregon250
Clunk!
Alright I got up under my truck today and noticed where the problem may be. I appears to be the drivers side tie rod (I think its a tie rod).
I grabbed a hold of it in the middle and shift back and forth and it has about 3" of play. The other side had no play? is this the probelm? Do I need new bushings or the whole tie rod?
Thanks,
Geoff
Old Jun 2, 2003 | 05:38 PM
Incommunicado's Avatar
Incommunicado
Clunk!
Hi,
I would first find out what you are refering to, it seems that you are describing the "center link" The cener link is attached to the pitman arm of the steering box, and the inner tie rods.
The tie rod ends are to the outermost and attached to the wheel spindles.
There are right and left tie rod ends with left and right handed threads (also for whatever reason left and right handed prices)
These are replaced as individual units and be sure to have your front end re aligned, after replacing
good luck
Old Jun 2, 2003 | 05:55 PM
oregon250's Avatar
oregon250
Clunk!
They are tie rods then. Judging from your explanation the rod goes to the drivers side spindle, so the left tie rod then shifts back and forth.
What I mean by back and forth is the if I grasp it with my hands and shift my hands up and down I get play. This doesn't seem right to me.
I have to realign it even if I mark the area around the sleave? Also do I just get the two bushings with the bolt or do I get the whole tie rod.
Old Jun 2, 2003 | 08:59 PM
Incommunicado
Clunk!
Hi,
The tie rod ends come with the threaded end (left hand and right hand). If the post has play in the tie rod socket, the entire tie rod ends needs to be replaced.
Re: The wheel alignment, the wheels should be realigned, although when removing the tie rod end count the number of turns to get if off and then thread the same amount of turns to install. This will get you into the neighborhood
shore
Oct 21, 2021 03:50 PM
TrevorP
Jan 26, 2008 12:23 PM
Mac 25
Nov 26, 2003 06:23 PM
TEEJAY
1997 - 2003 F150
Jul 4, 2003 11:43 PM
