Exploding radiator - No, really - EXPLODED
Old Feb 15, 2013 | 09:46 PM
MHDtr33's Avatar
MHDtr33
Anyone every seen anything like this? Any idea what would cause this? I just bought this '69 (today, and blew it up on the way home) and don't know much about it yet. Compression is good... ??
Old Feb 15, 2013 | 09:53 PM
68cabby's Avatar
68cabby
Sweet Jesus!
Old Feb 15, 2013 | 10:06 PM
CB28424's Avatar
CB28424
WOW!!! It may have had a leak and if the stop leak was added wrong it could have caused it, we had some one time that actually plugged a radiator whole I guess if it was clogged somewhere it could let go in a whole new way, that is bad.
Old Feb 15, 2013 | 10:09 PM
lucky_thirteen's Avatar
lucky_thirteen
Bad cap that didn't let the pressure blow out the overflow is my guess. I'm surprised the hoses held on longer than the radiator
Old Feb 15, 2013 | 10:19 PM
67dude's Avatar
67dude
Wow I've heard of it before but never saw one that bad. Where are you located?
Old Feb 15, 2013 | 10:24 PM
MHDtr33's Avatar
MHDtr33
Austin, TX
Old Feb 15, 2013 | 10:26 PM
JWC 3's Avatar
JWC 3
I saw something like that when a guy put a gallon of gas in his radiator to " get er home " Wow ! That would tighten the sphincter while driving a new buy home !
Old Feb 15, 2013 | 10:49 PM
Gembone's Avatar
Gembone
blown head gasket pushing exhaust into the cooling system would cause enough pressure for that.
That is one heck of a blown radiator though.
Old Feb 15, 2013 | 11:01 PM
Riderman's Avatar
Riderman
I had a 67 cheby station wagon do about the same thing. It's radiator was about as rotton as yours. I put a new radiator in it and had no other issues.
PS. I will add this, when you replace that rotton radiator with a new one, fill it up to about an inch below the opening (there are procedures on here for burping the air out) and see if you continue to get air bubbles\foam in the antifeeze. If you do, it is probably due to a blown head gasket or cracked head. That would over pressurize your cooling system. Then add an aftermarket coolant overflow kit.
old broke prospector's Avatar
Steam caused explosion in the radiator
Nice steam explosion, usually the cap lifts or a hose blows or a seam blows out long before a radiator blows apart like this. Great pictures. The radiator will make a good wall hanging in your shop. Good thing you were not bending over it when it blew. Take it to the local radiator shop and ask them to repair it.
Thanks for the pictures.
Old Feb 15, 2013 | 11:11 PM
cofferjl's Avatar
cofferjl
I would second that guess. I had a 48 ****** jeep that did something similar just not as violent. It had sat forever, I got it running changed hoses and after running a little while I heard a pop then saw some steam. I found a small crack, got it fixed, got a new cap, put in a new thermostat then worked like a charm.
I bet that made quite the sound. Looks like a pretty cool truck and now you have a great story to go with it.
Old Feb 15, 2013 | 11:33 PM
MHDtr33's Avatar
MHDtr33
Compression between 90 (1 cylinder) and 110 psi means not head gasket, right?
(I have one at 90, 4 at 100, and 3 at 110)
Old Feb 15, 2013 | 11:36 PM
MHDtr33's Avatar
MHDtr33
I checked compression. Between 90 and 110 all the way around. Doesn't that mean I can rule out leaking head?
Old Feb 15, 2013 | 11:51 PM
Riderman's Avatar
Riderman
Yea, I agree with you on that. With the pictures you provided, there is no doubt the radiator is rotton. I think if you replace it with a "new" one, you will be fine. The junk yard radiators are probably as old as your original.
Old Feb 16, 2013 | 03:30 AM
mkoch96's Avatar
mkoch96
For one, I would think that the radiator cap was stuck since it didn't vent off the pressure. There may have been another problem which caused the excessive pressure in the first place. I don't know how much would be created by simple temperature expansion.
