I had a rotten radiator do that but not as extreme while it was sitting in the drive way and running. I was adjusting the carb at the time ,the hot water got pretty close to me.
Sorry, trying to get advice/opinions from as Ford guys as possible, as quickly as possible. Annoying how there is not a more general area for this. Site is divided into so many subgroups that I thought I ought to hit a few.
Best to ask on the thread that covers the year of your truck on most questions. I could see you were kinda new here and was not sure of how the forums work. It's really not unusual to have one explode like that if they are old and rotted out. I'v seen it happen a few times working around industrial and farming equipment that was worn out. It can happen to a good radiator if the cap is bad but most of the time one of the hoses will blow first. I had one on an 87 f-350 blow the plastic drain valve off of the bottom of the radiator, it had a bad cap.
I flushed my 64 with Prestone radiator flush. It broke so much corrosion free that the overflow got stopped up. When the cap tried to release the pressure it had no where to go. Fortunately my top reservoir only ballooned out before I figured out what was going on.
WHHOOAAWWW! That is a crazy image! New radiator & cap. Since your putting in a good radiator. I would spend a few bucks on freeze plugs, pop the old ones out, remove thermostat housing and flush the block with a hose from every angle possible.
I'd contact prestone or ? and see if they want to buy the image LOL!!
The compression numbers that you have posted are not alarming for a tired engine. The difference between the two cylinders does not mean a blown head gasket. Your compression numbers are even. That says okay to me.
Do you see any water on the dipstick?
Do you see any oil contamintion in the overflow tank?
Do you see any balooning of the hoses?
If the answer to all three is no, your problem is a lousy solder job on the tank or just plain old age. Replace the radiator and cap and the old girl will run for another ten years.
I'm glad no-one was standing over it when it blew!
Here's my theory as to what happened: First the cap stuck and wasn't venting pressure, then the truck began to overheat. Since the system was still pressurized, the water didn't boil, it just kept building more pressure, then the top seam in the radiator blows out. The system is no longer pressurized, so all that water that is above the boiling point flashes into steam, and BOOM!
Basically just like a boiler explosion on a locomotive or a powerplant, just not nearly as bad.
Sam
Sounds good to me . My 50 Ferguson just lost the top . Side broke loose and she poped off .I was able to resodder it back together .Took a while to fix . In the woods , cutting firewood , limp her home ! That sucked .Then cold outside , heat up garage , At least mine was not as bad as this one . My rad was fixable .
