Welders?
Old Feb 15, 2013 | 07:26 PM
Faber's Avatar
Faber
Welders?
I'm looking at welders. Floor pans, body panels, probably shock mount repair.
I'm a cheap *******, but who isn't.
I've heard flux core can be done on body work with tack Weld and cleanup. I've heard gas mig is best. I've also heard stick works.
Cheap flux core $270
Mig gas/flux $500
Stick $300
Basically looking at home depot crap.
Fire away, advice/thoughts?
Old Feb 15, 2013 | 07:38 PM
davewave649's Avatar
davewave649
I got a refurbished Hobart welder for about $500 2 years ago. It comes set up for flux core but comes with a regulator so when you want to get shielding gas you just have to buy a tank. Its done everything ive wanted to too so far. Itll weld up to 1/4" steel
Old Feb 15, 2013 | 07:42 PM
66 twin i's Avatar
66 twin i
A coworker of mine bought a Eastwood 135 mig a few years ago. He likes it and hasnt had anyproblems with it.
Old Feb 15, 2013 | 07:45 PM
Faber's Avatar
Faber
Have you done anything as thin as body panels with flux core
Old Feb 15, 2013 | 07:46 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I also bought the Eastwood 135 mig. Decent little welder. You could go without their cart and save some $$, but you'll need a helmet, gloves, and a bottle of gas. Mig pliers are very handy, too. The spool of wire it comes with is for use without gas but you'll need 120V @ 25 AMP to run that.
Old Feb 15, 2013 | 07:51 PM
Redmanbob's Avatar
Redmanbob
All will work, some requiring more talent than other, some more prep, some more debur.
Stick, only thing i would attempt is shock mount repair with 1/18 7018-R
You can stick sheet metal with 6013-R but if you aren't real good with stick "PASS"
Flux (CAN BE RAN IN A mig MACHINE) core is cheap, but spend the money on a step up in machine. Plan on lots of follow up with a wire wheel, same prep as mig.
Mig: is the best choice as it will be the cleanest and require same prep as any really. Only thing about it is you cant bend the rod and use a mirror for the tricky spots
If you are not already familiar with welding, plan on a real joyride with sheet. I would get some scrap sheet and run an entire 12lb roll before getting at the truck.
Push dont pull, you want the gas on the bead, vertical is always bottom to top as the name implies zig zag or frown face work great.
I have a 08' Miller 180 Autoset and love it!!
A 48' Lincoln SA200 / Wisconsin VF4
and a 87' Lincoln 275 Ranger the most versatile of the pack for sure.VID_20120324_111143.mp4 Video by GrumpyBobby | Photobucket
Old Feb 15, 2013 | 09:16 PM
cobraguy's Avatar
cobraguy
I have an older, 10-15yrs, Lincoln SP125 I got on Craigslist for $100, bottle and regulator were another $130. I run the smaller .023" wire for body work and exhaust. Everything else I stick weld. Flux works just like mig but its messier and slags up more. I'd shop craigslist for a used name brand rather than a new Harbor Freight unit.
Old Feb 15, 2013 | 11:13 PM
Redmanbob's Avatar
Redmanbob
check out thermal arc, they make a nice 3 in 1 unit.
Thermal Arc® - Home - Arc Welding Equipment Technology Leader
Everlast USA makes a multi process unit as well.
http://www.everlastgenerators.com/pr...tegory-61.html
Welders are something you want to look at the big picture when buying. Don't buy one based on the requirements of a project.
Old Feb 15, 2013 | 11:20 PM
Faber's Avatar
Faber
Appreciate the responses. I gotta aim on the cheap. Sounds like mig is way to go, but base model quality name flux (without gas option) is cheaper along with needing more practice and cleanup.
How important is it to move from crap model with the preset options to variable dial options?
Old Feb 15, 2013 | 11:33 PM
Redmanbob's Avatar
Redmanbob
rheostat vs digtl, I vote old school. Works and when broken, cheap to replace. Presets are ok, but if you default to a dial (promise) you may never feel/hear a good weld and know it's spot on. If cheap is it, I might go Harbor Freight TIG (new) For the $ you might spend on a shelf welder, you might inquire at the local High-school, or College to see if they might save you time, $ and headaches.
Old Feb 16, 2013 | 07:23 AM
Faber's Avatar
Faber
Not a bad idea. Though i do qc for a bridge building company, so if i want have someone else do it or borrow some real big/good equipment, id go through work. Right now I'm just looking to have something of my own that stays at home.
Old Feb 16, 2013 | 01:37 PM
charliemccraney's Avatar
charliemccraney
I'd get a flux core welder that that can be converted to gas in the future. It will cost a little more but it will be worth it. That will allow you to upgrade as the funds become available.
The real cheap flux core units typically cannot be converted.
Old Feb 16, 2013 | 06:07 PM
Faber's Avatar
Faber
Lincoln Electric, Weld Pak 140 HD Wire-Feed Welder, K2514-1 at The Home Depot - Mobile
Went with this, more i planned on spending. Hopefully don't regret it.
See how goes.
Sure appreciate everyone advice.
Old Feb 16, 2013 | 06:48 PM
charliemccraney
I think that's an excellent choice.
Old Feb 16, 2013 | 07:13 PM
Redmanbob's Avatar
Redmanbob
You'll be happy, they weld just fine for a 110/120V unit. Be aware even though they say aluminum wire is an option. It will not work worth a crap without a spool gun. Don't try it unless you like birds nests,
Get some beads ran and show us what your working with!
Flux doesn't require gas but the prep needs to be just a pretty, take your time with it. Wiping with lacquer thinner after brushing will help a lot.
!!"DO NOT USE BRAKE CLEANER TO PREP"!!!
Brake Cleaner = Phosgene Article
