Mis-firing, ignition probs
Old May 30, 2003 | 05:34 PM
4AVIEW's Avatar
4AVIEW
I have a '95 f250, 5.8. Comp code coming up is 211 (erratic ignition). It's mis firing, when under any amount of load, I can hear a relay clicking under the dash. It clicks in timing with the mis-fires. I would rather start buying parts and changing them out than take it to a shop. Besides plugs, wires, cap-rotor...what else should I change? Any sensors, modules, etc.?
Old May 30, 2003 | 10:46 PM
Franklin2's Avatar
Franklin2
Do the simple stuff first that you listed. Also just spend some time checking wiring connections. Don't be afraid to pull a wiring connector apart, have a look, and then put it back together. Also check any vacuum lines are cracking too.
