runs bad when cold
Old Feb 19, 2013 | 10:20 AM
Brother Les's Avatar
Brother Les
Originally Posted by bossgobbler
I want to go ahead and try the easier fixes first as don't know what was done to this truck before I had it, so may as well go ahead and do it. Then, do the injectors after that if still having problems. I'll post back after I finish the easier fixes and will read the codes again and see where we are.
Thanks again for all your responses. I appreciate the help.
Is the ICP covered in oil and leaking? Unplug it and leave it unplugged and see if your truck runs better.
Old Feb 20, 2013 | 05:04 PM
kdv's Avatar
kdv
I have a 99 with 270K miles on it. Over the past few months, noticed that when I start it in the morning it idles a little rough. Also, if I don't let the truck warm up for at least 5 minutes, it has problems accelerating. If I let off the gas when it does this and pull over to the side of the road and sit until it warms up, then it runs fine, but if I don't let off the gas and keep trying to accelerate the truck will die and it won't re-start unless I let it sit for a while. These symptoms are worse the colder it is outside. If it's hot outside, it doesn't have this problem.
I have the AE code reader and these are the diagnostic codes i'm getting.
P0472 Exhaust Pressure Sensor Low
P1212 Injector Control Pressure lower than desired
P1247 Turbocharger Boost Pressure Low
P0340 Camshaft Position Sensor A Circuit (Bank1 or Single Sensor)
KOER Cylinder Contribution test
P0284 Cylinder 8 Injector Circuit Contribution/Balance Fault
What do y'all think this might be? Where should I start to try and diagnose this problem. I've searched this forum but haven't had much luck finding a solution. Any suggestions will be greatly appreciated.
How cold is cold ? If it is cold temps out you should try and let the motor warm up some anyway.
Old Feb 21, 2013 | 10:57 AM
JMP E350's Avatar
JMP E350
I have the same problem ... Poured some SEAFOAM in the oil fill tube to thin the oil a little to help with cold weather (michigan 20 deg.)
Yes you have to let it warm up! or plug it in..
also I believe the clearance on the poppets is .002 .. not .004 but Im not currently looking at the shop manual .. i know you can shim them to get the clearance -
ill check and re-post
Old Feb 21, 2013 | 11:57 AM
fordpride's Avatar
fordpride
Clearance for a new injector is .004 and you can shim the armature plate to get it closer to the solenoid. But that's not fixing the problem it's only a band-aid cause the poppet is still worn into the injector body
Old Feb 21, 2013 | 12:06 PM
fordpride's Avatar
fordpride
http://www.dieselpro.ca/Poppet%20Valve.pdf
Old Mar 12, 2013 | 11:51 AM
bossgobbler's Avatar
bossgobbler
I finally got around to trying to figure out this problem and it was a simple fix. I was real low on oil. Changed the oil and filter and it runs fine now. I may have an oil leak somewhere.
Old Mar 19, 2013 | 05:18 PM
Tailgate77478's Avatar
Tailgate77478
Well, let's hope that fixed it! Thanks for posting the update!
Pikachu
Dec 8, 2015 08:03 AM
Shepherd2
Feb 26, 2014 05:03 AM
yeomansjon
May 21, 2012 09:55 AM
snakedoc
May 9, 2012 08:56 AM
ccg711
13
Mar 10, 2007 08:55 PM
