Sponsored by: Real Truck
Rear u-joint greasing
Old Feb 14, 2013 | 12:09 PM
Buck268's Avatar
Buck268
This is a kinda basic non-issue but I was curious if anybody had a good method. I had my OEM driveshaft overhauled with fresh Spicer greasable u-joints and a balance back in the fall. Now I really don't intend to debate greasable vs. sealed u-joints as both work well if they are a good quality unit in my experience, though for my use a sealed unit is maybe a better fit IMHO. Any how went under there today to do the first regrease since the shaft was installed and was happy to notice they did the job right and all the zerks were lined up. When I got to the rear u-joint though I noticed the clearance to fit the grease coupler was rather tight- in fact I had to position it so the zerk was pointed straight up and then I had to apply a good amount of manal pressure on the coupling to prevent leakage due to the interference with the coupler and the surrounding joint/driveshaft.
Has anybody else run into this problem? If so, did you come up with any suggestions? This joint sees a lot harsher environment and anything to make greasing easier would likely increase the frequency of greasing and thus the longevity... ya know?
Old Feb 14, 2013 | 01:00 PM
SuperDutyScaler's Avatar
SuperDutyScaler
no my u-joints do the same thing, i know this isnt what you want to hear but this is what i do...
remove the four bolts from the pinion
remove the shaft
grease the slip joint
then i grease the u-joints
reinstall the shaft and bolt her back up, i do this ever three to four months. takes about twenty minutes
Old Feb 14, 2013 | 01:03 PM
SuperDutyScaler
did you have the double carbon joint rebuilt also? i didnt do mine when i installed my ujoints and i have a small vibration between 60-70mph
Old Feb 14, 2013 | 08:03 PM
Buck268's Avatar
Buck268
Other than the fact that is even more work than what I had to do today, and that the slip joint isn't supposed to require that type of service interval with the proper PTFE grease, what concerns me is that those straps are supposed to be one time use. I could see reusing them, especially if they are low miles but frequently doing so would make me worry about metal fatigue.
As for the double cardan I honestly don't remember. Had it done through an inside connection and didn't get an official itemized bill. They did a top notch job though, even balanced and painted so I suspect if it was needed it was done.
I wonder if an angle head zirk would work, might have to take a closer look next time and see... though I am not optimistic.
Old Feb 15, 2013 | 01:01 PM
SuperDutyScaler
what straps are you talking about? SD ujoint are in a closed bracket only bolts hold the end onto the out put shafts.
Old Feb 15, 2013 | 04:10 PM
Kdr358's Avatar
Kdr358
Front shaft maybe?
Old Feb 15, 2013 | 09:22 PM
Buck268's Avatar
Buck268
These secure my rear driveshaft rear u-joint to the pinion yoke.
Old Feb 16, 2013 | 08:16 AM
meborder's Avatar
meborder
remove the shaft
there is a MUCH easier way!!!
you need this:
NAPA AUTO PARTS
has a zerk on the back to hook into your grease gun then a long hollow "needle". the end of the needle is exactly the right size to depress the ball in the zerk on the u-joint. just hook it up push it up against the zerk and pump.
works like a charm! i will NEVER do u-joints any other way again.
a mechanic at work told me about these.
i got mine at napa ... just a few bucks.
get one, you won't regret it ...
Old Feb 16, 2013 | 08:06 PM
Buck268's Avatar
Buck268
Hmm, very interesting! Just spent $6 for a 90 degree slide on adaptor to facilitate rediculously easy upper ball joint greasing maybe I'll spoil myself next oil change with that needle- at least to give it a try.
Old Feb 17, 2013 | 08:27 AM
SuperDutyScaler
dude dont put that 90* in your upper balljoint! As soon as you use 4wd the axle shaft will spin and snap the fitting clean off
Old Feb 17, 2013 | 08:54 AM
Buck268's Avatar
Buck268
No, its a 90 degree nozzle for the grease gun! Works like a champ, too.
alloro
34
Jul 14, 2018 09:55 AM
Nathan Plemons
Apr 18, 2010 01:31 PM
jsparrow
Sep 15, 2009 12:37 PM
cpettymore7777
Nov 2, 2004 11:52 PM
superrangerman2002
1997 - 2003 F150
Aug 19, 2004 11:56 PM
