Fuel pump question..
Old Feb 14, 2013 | 09:16 AM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
Lately I have been hearing a humming noise that I believe is my fuel pump, while driving, sitting at light etc. Is this normal? Never really noticed it before and I've had the truck since I bought it new in '04.
I seem to remember when at start up I would hear it run for a few seconds then turn off...now it just seems constant.
Old Feb 14, 2013 | 09:32 AM
mhoefer's Avatar
mhoefer
Are you sure it's not your vacuum pump? Is it under the hood by the passenger side battery? That means you have a vacuum leak. Heater control will default to defrost often in this situation until pump catches up.
Old Feb 14, 2013 | 09:35 AM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
The humming is coming from the driver side. I hear it when I turn the key on before start up and while running.
Old Feb 14, 2013 | 10:06 AM
dannyboy950's Avatar
dannyboy950
Only thing I can think of off the top of my head is trash in the regulator keeping it from closeing or a injector dumping fuel in a cylinder. Bad/stuck pintle.
Neither of which is good. If it has been doing this awhile check your oil for fuel dilution. If it is bad enough you can hydrolock.
Old Feb 14, 2013 | 10:28 AM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
Honestly not sure how long its been doing it. I usually have the radio on so I cant notice it but last week I had the radio off and have been noticing it.
Could a dirty fuel filter cause this?
Old Feb 15, 2013 | 05:01 AM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
Best I can tell my oil seemed fine.
Is there an additive I can use if something might be stuck??
Can a bad FICM keep the fuel pump running? I had it repaired a few years ago with Ed but I had to replace my alternater and batteries 5 months ago because alt. was going bad.
Old Feb 15, 2013 | 06:55 AM
mustang_309's Avatar
mustang_309
I believe the fuel pump is commanded to run continually once the engine starts, otherwise the fuel pressure wouldn't remain consistent.
Old Feb 15, 2013 | 07:00 AM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
When you turn your key on (engine off) does your fuel pump turn off after a while before you start your motor?
Old Feb 15, 2013 | 07:03 AM
mustang_309
Yes the PCM commands it to start for a specified amount of time when the key is initially turned on then it shuts off.
Old Feb 15, 2013 | 07:04 AM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
Thought so....Mine stays "on".
Old Feb 15, 2013 | 07:11 AM
mustang_309
Im not sure what would make it stay on as there is no pressure switch that I am aware of that would tell the PCM when to turn the pump on and off, or under what circumstances the PCM will command the pump to run. One of our resident tech's or perhaps Blades, Bullitt390 or Bismic would know the answer.
Old Feb 15, 2013 | 07:15 AM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
Appreciate you at least confirming that yours shuts off. Mine stays on from key turned on till I'm to my destination and I turn the motor off.
I travel 40 miles to work and it's on the whole time.
Old Feb 15, 2013 | 07:58 AM
livinlots26's Avatar
livinlots26
I'm thinking something is holding the return spring open and it can't build to the pressure it needs. Does the truck still run fine? If you decide to check the fuel return spring you might as well get the blue spring update its a full kit with new o rings and plunger. You can get it cheaper at an international dealer at around 40 bucks. When is the last time you changed fuel filters and what brand did you use?
Old Feb 15, 2013 | 08:25 AM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
Truck runs fair but it's been like that for a while. runs like crap at first start up but gets better as it gets warm.
Been a long while (years) since fuel filters were changed and it was done at the dealership.
As far as the fuel return springs...never heard of them.
Old Feb 15, 2013 | 09:41 AM
mustang_309
You haven't changed the fuel filters in years? Does it have new filters in there now? If not that's where I would start, and make sure you use OEM filters.
