e4od controller question (IDI)
Old Feb 13, 2013 | 12:24 PM
batchman's Avatar
batchman
Hi, I'm trying to update my '86 f350 2wd/6.9L/C6 to e4od. On much good advice in these forums I've got my hands on (and rebuilt) a 1990 e350 2wd/7.3L and thought I had the controller but turns out I've got the brake module instead, and the donor truck is now gone (rebuild took a long time).
I gather there is a difference between 2wd and 4wd on the controller.
My real question is what concerns may I find if I use a different year control box? One comment I saw indicated the later the better for these, but is there a difference from an interchange standpoint?
Trying hard to avoid buying an aftermarket controller if I can do this with factory parts... I think I still need to figure something out for the column sensor too - maybe?
Thanks,
- Jeff
Old Feb 13, 2013 | 02:04 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You gather wrong. Same controller. The 4x4 has a wire that tells the controller when it is in 4x4L. As long as that circuit isn't grounded it works the same.
Any year 1988-1994 will work, the later ones will work better.
Column sensor? I don't know of any column sensor. What would it do?
Old Feb 13, 2013 | 02:32 PM
batchman's Avatar
batchman
Thanks, Mark - that's encouraging!
By column sensor I mean the MLPS, presuming my neutral safety switch isn't going to give enough info to the controller.
I am also hoping upon hopes that the color codes don't change much through the years, the underside harness I have is from the '90 donor.
Best,
- Jeff
Old Feb 13, 2013 | 05:59 PM
Mark Kovalsky
The MLPS is on the transmission, not the column. The sensor was the same from '88-94 as I remember it. But on the other hand, that was a long, long time ago.
Old Feb 13, 2013 | 09:15 PM
batchman's Avatar
batchman
That, sir, is *awesome* news.
Thanks again,
- Jeff
good to doo
Oct 24, 2016 09:21 AM
first today
Nov 8, 2010 07:46 PM
rig2
Mar 24, 2010 10:03 PM
351coupe
Nov 8, 2009 12:25 PM
Dads79
Jan 7, 2007 04:39 PM
