No power when driving
Old Feb 16, 2013 | 01:20 PM
hakukamana's Avatar
hakukamana
OK here's the latest I did a buzz test this morning and it came back as follows: P1293 High Side Open Bank 1 (right) Not really sure what that means as far as checking?????
Old Feb 16, 2013 | 01:58 PM
hakukamana's Avatar
hakukamana
Just ran a cylinder contribution test and it read as follows: PO263,PO269,PO275,PO281 Cyl1,3,5,7 contribution or balance malfunction. The valve cover harness?
Old Feb 16, 2013 | 05:53 PM
oldbird1965's Avatar
oldbird1965
Could very well be. A burnt pin is hard to see sometimes. Use a magifine glass and take a good look.
Old Feb 16, 2013 | 06:48 PM
Action4478's Avatar
Action4478
I know whats wrong but don't have the energy to deal with the mis information here any more . Post back when you figure it out ...
Old Feb 16, 2013 | 08:11 PM
hakukamana's Avatar
hakukamana
After removing the valve cover and checking the connectors twice and rerunning the buzz test. The right bank buzz's very softly, while the left bank is horns a blazin. Went to the IDM, removed the unit and did a very scientific test of the component, I shook the h_ll out of it, water in the IDM, unless there is some kind of liquid connector inside this thing. I will look into a reman, to install and hope the troubles will be solved.
Old Feb 16, 2013 | 08:34 PM
oldbird1965
Some guys have taken it apart and let it dry and it worked OK after. Seems amazing but I have read that!!
Old Feb 18, 2013 | 09:36 PM
hakukamana's Avatar
hakukamana
OK am I on the right track, IDM failure due to water in the unit?
Old Feb 18, 2013 | 09:51 PM
oldbird1965
Yes, if it had water in it then that explains the problems.
Old Feb 18, 2013 | 09:58 PM
fordman67's Avatar
fordman67
Now Rick...dont give up on us just yet...please..
Old Feb 21, 2013 | 07:12 PM
hakukamana's Avatar
hakukamana
Still don't have my new IDM yet so I did a little more testing on the engine harness. Trying to figure out the P1293 DTC, I checked PIN C which is supposed to have battery voltage with a KOEO situation, my readings were about 1.8 to 1.7 volts. I checked both connectors ORG wire, and same reading. Does this lead me back to a faulty IDM?????
Old Feb 25, 2013 | 08:44 PM
hakukamana's Avatar
hakukamana
OK a new IDM and a new UVC harness and I got a good buzz test and it started and idled great. Took it out for a drive and the first couple of miles ran like a beast. Then, some bucking, rpm flucuations, the check engine soon light on then off then on, almost felt like it was starving for fuel. Got her back to the house would idle fine then run rough, then idle would speed up, and surge. Now what am I dealing with????
Old Feb 25, 2013 | 09:03 PM
fordpride's Avatar
fordpride
Check the codes again
_Me2_
Aug 11, 2011 05:02 PM
agg_bagg
Jan 10, 2011 01:44 PM
Diesel nut
Oct 6, 2009 09:57 PM
6CylBill
92
Jun 25, 2009 04:46 PM
jnye6625
Oct 10, 2004 09:11 PM
