ebpv sensor bypass info needed
Old Feb 12, 2013 | 07:18 PM
MONAVIERONJON's Avatar
MONAVIERONJON
Did the EBPV delete on 97 psd, as well removed the tube by the front timing cover and capped the manifold off. Had someone swipe my EBPV sensor and the long metal plate it is secured on. So .....had an extra long black plate with a sensor that has the plug clear broken off so the sensor is basically worthless. The wiring pigtail is just hanging there because there is no recepticle to plug it in. Now have a no start because of it. Does the three wires (Brn.Wht , Ppl Lt Blue, Gry red) need to be all connected to close this circuit to be able to start the motor? Thankx........Again!
Old Feb 12, 2013 | 07:54 PM
84-250's Avatar
84-250
Having the EBPS unplugged only triggers a p0472 code, truck still will run
Old Feb 12, 2013 | 09:03 PM
MONAVIERONJON
thankx, good to know, schematic shows one wire goes to icp and one wire eec with the 3rd going to ebpv. guessing on this and will pull codes tomorrow after i do the clutch interlock bypass.
SUPERDUTY OUTLAW
32
Jan 19, 2018 09:41 AM
fordman837000
Dec 12, 2007 11:07 AM
dogg16
Bronco II
Aug 17, 2004 12:11 PM
rgillies1986
Jun 25, 2004 01:56 PM
nmaineron
Mar 8, 2002 01:07 PM
