Sponsored by: Real Truck
Need help please
Old Feb 12, 2013 | 10:12 AM
Collinsmatt's Avatar
Collinsmatt
Need help please
I have a 2001 f250 4x4 v-10. When I put the truck in gear, it makes a loud clunk. So I replaced the rear uv joints hoping to fix the problem. This didn't help at all. Also, when its in gear and I'm at idle speed, I can hear and feel some type of grinding. When I hit the gas, and put torque on everything, the noise goes away and the truck runs fine. Only when there is no torque applied is when I have problems. Are the two issues connected? Any info would help. Thanks
Old Feb 12, 2013 | 10:59 AM
bubbasz1's Avatar
bubbasz1
The clunk can be made by the slip yoke on the drive shaft being dry(no Grease), see if it has a grease fitting, if not you'll have to drop the shaft and grease it, mark it before dis-assembly and assemble in the same orientation. See if that helps.
cashcrazy
Jul 14, 2018 11:21 AM
xtheomanx
Jun 25, 2011 01:42 PM
pfish
Apr 22, 2009 12:45 PM
9explorer8
Apr 23, 2006 06:46 AM
swenson
1978 - 1996 Big Bronco
Aug 22, 2002 01:13 AM
