6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
DPF delete thread #234129038407
Old Feb 12, 2013 | 01:04 AM
Dorito's Avatar
Dorito
Can anyone give me some solid advice about deleting my DPF and cat. Can I get away with a mild tune or just the delete tune?
I want better MPG, but I am not interested in spending $2000 to get it. The prices of delete kit sand tuners are all over the map. Some are cheap and some are off the charts.
Before I get scolded, I did do a search and found tons of conflicting information. Maybe we can pile all the information into one thread.
Has anyone ever gone to a local muffler shop and had them build the cat/dpf delete pipe? From what Ive seen it doesn't look too complicated.
Old Feb 12, 2013 | 05:18 AM
senix's Avatar
senix
DPF R by gear box z maybe your ticket. Easy to plug into the OBD port and program the truck for DPF off and no gains.
Still have to buy the straight pipe though.
Not too expensive either.
Old Feb 13, 2013 | 06:31 PM
BROWN DOG KTM's Avatar
BROWN DOG KTM
Originally Posted by senix
DPF R by gear box z maybe your ticket ...
+1
I love mine
Old Feb 13, 2013 | 07:21 PM
WMDPSD's Avatar
WMDPSD
I got a h&s I like the tuner, but I only get ten miles to the gallon. That is short trips up and down hills pulling a trailer every tank. Love the no regens and the power. Not crazy about the shifting. But it was worth the thousand dollars to not have to put up with "drive to clean exhaust" message.
Old Feb 14, 2013 | 02:43 PM
StanleyZ's Avatar
StanleyZ
OK, I'll take a shot. Solid advice: there are a number of reasons to delete, the truck will run better, it will have more power, your engine oil will not be deleted so the engine should last longer. There are 2 reasons not to, three if you think we are capable of doing something that would alter the earth's atmosphere: It cost money, it is a violation of federal law. The decision is yours and yours alone.
The increase in MPG will not be much, let's say 15 to 20 percent. You will not get 20 MPG or aqnything near it. But it will payh for the tuner in a year or two.
I would be suprised iy a muffler shop would build you a pipe for less than they sell for on ebay but any shop should be able to do it.
The posts above have a couple tuners thatr sell for cheap. You need to know that Edge and H&S have both stopped making tuners that will allow you to delete the DPF. According to the EPA they fined Edge 500,000 bucks. So probably the other companies will get the same treatment soon. So, barring a new entry into the market from Mexico or somewhere delete tuners are the cheapest they will ever be right now. The scarcer they get the more they will be worth.
I think I got everything, oh yeah, FWIW there was an H&S on the detroit craigs list for 950 (I Think) the other day. Hope this is helpful.
Old Feb 14, 2013 | 03:43 PM
bigjr2's Avatar
bigjr2
I know im going to get yelled at but my H&S took me from 8-9mpg to 12mpg in city to up to 18mpg highway usually around 16 or so I run the mild tune or its called tow now since last update. My favorite camping spot is a 2 1/2 hour drive pulling my 5er i would roll inot town with 1/4 tank left now I got a little over 1/2 tank. Ok let the beatings begin LOL ohhh and stock set up no lift no big wheels.
Old Feb 14, 2013 | 06:29 PM
StanleyZ's Avatar
StanleyZ
I won't yell but I will say this, if the tuner got you a 50% increase in fuel economy (8 mpg to 12 mpg) or anything near that you truley have hit the jackpot. If the H&S tuner could do that they would have sold untold hundreds of thousands of them. Don't forget they work on a lot of trucks some of which have no DPF.
I don't know what truck you have but I guess an F 250 Extended cab with a 3.31 rear axle on a level run could get close to 18, or as you said " usually around 16" which sounds like it's often in the 15 to 16 range. That's doable, but far from 20.
rjlabonte
Jul 9, 2014 08:35 PM
Machinator
Nov 27, 2010 06:33 PM
millerstroker
Jun 23, 2010 08:08 PM
c dogg
Nov 5, 2009 02:00 PM
neb44
Nov 24, 2004 11:57 PM
