AE in Nevada
AE in Nevada
Please add me to the Best of AE. My AE arrived on Saturday from RiffRaff. If you're in need of assistance while in the Reno/Sparks area of Nevada my AE will be available. I'm also ASE certified in Engines and Parts.
Now to start learning the AE on our trucks. I do have a question.
I've installed the software and read the user's guide yesterday. Does the AE bundle come with the sensor parameters or do we take the data the sensors show and then find the specifications in the service manuals?
Any tips about using the AE?
Thanks
Jeff
Thanks
Jeff
Thanks
Jeff
Thanks
Jeff
Welcome neighbor, to FTE ! I'm about 30 miles north of you (just north of Spanish Springs Peak). AE is relatively easy to use...I have had it for about 4 years and once in awhile I have a connection problem with the laptop, but I believe I have solved that problem.
I live on the north side of it. I'm only about 6 miles from you as the crow flies, but as you may know with Nevada being the most mountainous state in the country...there is no straight roads to anywhere (unless you go due north/south). Driving I am about 20 miles away. Let's get Jeff and the three of us meet up sometime...almost anytime is good for me.
Now that is a nice view Kinda of looks like the views we have at some property we have off of Whiskey Springs Road. Yes I think meeting some local FTE mates would be great. Not sure how to reach each other but let me know. The fact that Jeff is a ASE mechanic would be a great friend to have. Hope to hear back form the both of you. Work calls so you have a great day and keep enjoying that great view.
Lory (kinda like the boy named Sue)
Hey Guys..It's great to find members locally. I too, live in Spanish Springs.
Hey...let's meet at Bully's in Spanish Springs...I have Weds and Friday available....Lunch?
Well, I just finished up installing the FRx lines and turbo today.
Got the truck running, no leaks and hooked up the AE. First test: the KOER cylinder contribution test received P0263; Cylinder 1 injector circuit contribution/balance fault as a result.
Moved on to the Glow Plug Test....OK KOER Test...OK KOEO Test....OK
Injector Buzz Test....OK
I then pulled DTC's:
Gem Mod:
B1840, B1438, B1458..All have to do with washer fluid pump.
Then from the Enhanced Power Train:
P1119
P1690
P0475
P0460
P0470
I haven't yet researched these codes for future repairs.
Looking for any input on these DTC...Thanks....
Jeff
Gem Mod:
P1119
P1690
P0475
P0460
P0470
Jeff
Jeff, it gives you the output values of the sensors desired. If you go to Ken (woodnthings) website you'll find pdf's of almost all the sensors (if not all). I'll add you to the BEST map right now. We have to meet up one of these days.
Jeff
Jeff, I'd clear the codes and drive it for a few days...then reread for DTC's. I can do Friday for sure at Bully's, let's see what Lory can do.
Here is a link to DTC codes...
I've been around for several years now..Everyone is great!
Jeff
Friday is good for me say about 1PM depending on Lory's availability.
Jeff
