1981 Shift Indicator
Old Feb 11, 2013 | 06:14 AM
Leeboy1962's Avatar
Leeboy1962
I need to repalce the shift indicator on my 1981 F-150.Does anyone know the how to's?The cabel has broke,and I found a indicator assy. on E-Bay.Just need instructions on how to replace it.Thanks All
Old Feb 11, 2013 | 08:02 AM
Gary Lewis's Avatar
Gary Lewis
There's a black plastic cover that has to come off of the steering column. It is held on with one screw on the bottom, but once that's out you'll have to spread it open somewhat to get it off. It feels like it will break, but I've not broken one yet.
Once off you'll see a wire in a tube from the indicator around the column to a pin on the lever. The tube is held on with a screw with an arched washer. That must come off and the new one put back in its place. But, the tube is sure to be brittle so go gently with the new one. I've had them work fine even with a broken tube, but still use caution.
Old Feb 11, 2013 | 10:57 AM
Leeboy1962's Avatar
Leeboy1962
Thanks a lot.Very helpful
Old Feb 11, 2013 | 11:32 AM
ctubutis's Avatar
ctubutis
Yeah, the shroud needs to come off... it's the part in the picture but yours doesn't look like this and has only one screw.
You might need/want to remove a piece of plastic trim on the dash frame right at the steering column, I forget if it's in the way or not.
Old Feb 11, 2013 | 03:53 PM
Leeboy1962's Avatar
Leeboy1962
Shift indicator
Thanks guys.I got it changed out,piece of cake
Old Feb 11, 2013 | 05:49 PM
Gary Lewis's Avatar
Gary Lewis
Congrat's! Such a good feeling.
Old Feb 12, 2013 | 05:45 AM
Leeboy1962's Avatar
Leeboy1962
shift indicator
Thanks to all of you.This is a great site for help.THANKS ALL
daveinva
Nov 23, 2018 10:05 PM
Slip ford man
May 2, 2012 10:49 AM
orange784x
Apr 9, 2011 09:46 AM
F100FAN2
Mar 6, 2007 09:30 AM
ford1967
Nov 11, 2003 07:17 AM
